Question Relating B18C/CRX Swap With "L" Rear Bracket
Old Mar 6, 2007 | 09:25 PM
CW-ITR's Avatar
Default Question Relating B18C/CRX Swap With "L" Rear Bracket
When swap a B18C into an CRX, does the "L" bracket needs to be from a '89-'91 Integra or will the "L" bracket from the ITR fit? Thanks.
Old Mar 8, 2007 | 10:21 PM
locash's Avatar
Default Re: Question Relating B18C/CRX Swap With "L" Rear Bracket (CW-ITR)
90-93 Integra only.
Old Mar 9, 2007 | 03:35 PM
88ED8's Avatar
what trans. are you useing? if you use the 94+ hydro you need to drill the two lower bolt holes for it to eccept 19mm bolts...
Old Mar 9, 2007 | 10:30 PM
CW-ITR's Avatar
Default Re: Question Relating B18C/CRX Swap With "L" Rear Bracket (88ED8)
I'll using the JDM ITR tranny. The drilling you mention about is done on the "L" bracket right?
Old Mar 10, 2007 | 12:42 AM
88ED8's Avatar
Yep, the two lower holes...
ricardo13d
12
Jun 6, 2009 10:06 AM
CW-ITR
Mar 8, 2007 07:14 PM
Hapa88
Dec 19, 2004 08:12 AM
.Hookedonhatch.
Dec 22, 2003 01:35 AM
gocivicgo
Aug 16, 2003 07:19 AM
