Removing the black can!
Old Mar 6, 2007 | 09:03 PM
BoOsTeDtEg81285's Avatar
Default Removing the black can!
I have a 95' Integra and I have a black plastic can mounted in my engine bay on the passenger side. It has a couple of vacuum lines coming off of it, one that connects to the throttle body. What does this can do? Is it ok to just take it out and cap off the vacuum nipples?
Old Mar 6, 2007 | 09:11 PM
italianchooch88's Avatar
Default Re: Removing the black can! (BoOsTeDtEg81285)
are you referring to a catch can??
Old Mar 6, 2007 | 09:17 PM
Default Re: Removing the black can! (italianchooch88)
No. This is something from the factory. It mounts on the passenger fender well under the hood. It slides into its mounting bracket like the power steering reserve does. I think I've heard someone call it a coal can or something like that. Its not a catch can.
Old Mar 6, 2007 | 09:21 PM
KBG Indey's Avatar
its a charcol canister
Old Mar 6, 2007 | 09:25 PM
Default Re: (KBG Indey)
Ok, now I know what it is. What does it do, and can I just take it out or what?
Old Mar 6, 2007 | 09:42 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (BoOsTeDtEg81285)
It stores gasoline fumes and recirculates them into your engine later. It is an emissions device. If your car is OBD2, you will have a CEL if this is missing. Leave it in. Emission equipment is important. You will see no performance gains or losses. You may see a gas mileage drop. You will have to plug up the vacuum lines.
Old Mar 6, 2007 | 09:52 PM
Default Re: (B serious)
The car is OBD1, and its a fully-built turbo motor, so emissions and MPG aren't the biggest deal in the world. I don't even think this thing is fully connected. I just need to know how to take it out and plug up the vacuums.
Old Mar 6, 2007 | 10:04 PM
B serious's Avatar
unbolt, discard, enjoy. The vacuum lines can be plugged in your own creative way. Why do you wanna take it out, though? It's not doing anything bad just sitting there. You're basically going out of your way to pollute with no gain to yourself??? makes no sense.
If there is an electrical plug going to it, you will have a CEL even if its OBD1.
Old Mar 6, 2007 | 10:16 PM
I have the Hondata S300, so I can disable pretty much whatever I want! Muwhawhahaha!
Old Mar 6, 2007 | 10:20 PM
Jimmy's Avatar
Global Moderator
Your not going to get a CEL on an OBD 1 engine.. Remove-> throw away..
totsie7944
Feb 11, 2009 09:26 AM
maxogsr
Jan 7, 2009 07:49 PM
eg6madness
Apr 12, 2007 08:47 PM
94lsboost
Nov 4, 2005 01:27 PM
Soda Popinski
Mar 3, 2005 06:36 PM
