GSR exhaust on an LS? Whats the difference?
you can put an exhaust from a 94-01 ls on a 00-01 gsr and vice versa. but you cant put a 94-99 gsr exhaust on an ls.
If it's an Hswap in an ls or gsr, it won't make a difference, you're using a dif header.
The main difference in the gsr/ls, And in between years is the length of the bottom pipe on the stock header.
the stock GSR has a shorter header and a longer b-pipe, so u can cut the b-pipe to match with a LS header/cat combo if u wanted to.
