need help asap, im in the middle of my swap and...
Old May 22, 2002 | 08:51 AM
slowpokesi's Avatar
Default need help asap, im in the middle of my swap and...
i cannot find the knock sensor on the new engine,
1st gen b16a going into a crx si 91
cant find the knock sensor anyone know where it is?
[Modified by slowpokesi, 5:53 PM 5/22/2002]
Old May 22, 2002 | 09:07 AM
SuperCivic's Avatar
Default Re: need help asap, im in the middle of my swap and... (slowpokesi)
look on the back of the motor, in the center..can't remember if it's on the head or the block, but it's there..it's a round plug if i remember right.
Old May 22, 2002 | 09:09 AM
SuperCivic's Avatar
hmmm
[Modified by SuperCivic, 2:56 PM 5/22/2002]
Old May 22, 2002 | 09:10 AM
ricodemus's Avatar
yeah, compare your old wiring harness to the new engine and the plug that doesnt have a counterpart on the backside (by the oil filter) should be your knock sensor.
Old May 22, 2002 | 09:38 AM
turbo_ef9's Avatar
Default Re: need help asap, im in the middle of my swap and... (ricodemus)
it's right under the intake man like.. a lil above the altenator slightly to the right
Old May 22, 2002 | 09:46 AM
SuperCivic's Avatar
Default Re: need help asap, im in the middle of my swap and... (b16_ef)
now that i think about it, it's definately on the block. found it yet?
Old May 22, 2002 | 10:16 AM
Urban Business
Guest
Posts: n/a
Default Re: need help asap, im in the middle of my swap and... (SuperCivic)
HAHAHAHAHAHHHAHAH dont mess w/ texas
Old May 22, 2002 | 10:24 AM
slowpokesi's Avatar
Default Re: need help asap, im in the middle of my swap and... (TorteX)
okay i found it turned out that i had the wrong thing plugged into that part,
now i have only 1 extra plug on the entire harness, its like for 2 pins, and i have no fricken idea where it goes, im gonna go take a picture in a few.
Old May 22, 2002 | 10:26 AM
SuperCivic's Avatar
i had one extra plug as well..you're using the si harness, right? and the plug is floating around near the bottom of the intake manifold, right? i think yer golden dude.
Old May 22, 2002 | 10:28 AM
slowpokesi's Avatar
yah thats the one
i will brb so i can go take a picture of it
Old May 22, 2002 | 10:35 AM
2SLOWFORYOU's Avatar
What harness are you using? The stock harness or the hasport conversion. I'm in the process of doing my b20vtec in my dx and im using the stock dx harness with the addition of the extra wiring.
Old May 22, 2002 | 10:39 AM
slowpokesi's Avatar
Default Re: need help asap, im in the middle of my swap and... (B20CRX)
okay heres the pics, i will be back in about an hour to verify this, im going to go drop the motor in
Old May 22, 2002 | 10:40 AM
slowpokesi's Avatar
stock 91 si harness
alright i will check back in about an hour
Old May 22, 2002 | 10:45 AM
keithv's Avatar
get rid of that fram oil filter. they really suck...get a stock honda one or a bosch or something.
Old May 22, 2002 | 10:58 AM
WuShu's Avatar
New User
Default Re: need help asap, im in the middle of my swap and... (breaka_1_9)
Heres a tip, dont post your pic on the internet. But i do have to say man JOO LOOK!
Old May 22, 2002 | 10:59 AM
Stock honda is the way to go.
gen2fanatic
Feb 28, 2007 07:09 PM
WOODman
Jul 30, 2005 02:31 PM
T_Rex
Feb 3, 2003 05:09 PM
