Who runs a stock fuel pump?
The search function has been down for a while now so I started a new thread.
I just want to know if anyone here uses their stock fuel pump successfully. I'm going to be running 8 psi t3/t4 turbo d setup and I really don't want to replace the fuel pump in my crx.
Anyone do this and have problems running lean etc?
A Walbro is cheap. Why chance it? On a friend's car we were able to get to 320whp (I think, not sure of the fuel pressure) before it leaned out at 8000RPM. Next day he got a fuel pump and made 360whp revving to 9100RPM with no problems
I forgot to mention I'll be using hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t »</TD></TR><TR><TD CLASS="quote">A Walbro is cheap. Why chance it? On a friend's car we were able to get to 320whp (I think, not sure of the fuel pressure) before it leaned out at 8000RPM. Next day he got a fuel pump and made 360whp revving to 9100RPM with no problems</TD></TR></TABLE>Because, it's a pain in the *** to get to the fuel pump in a crx on jackstands in your garage. Especially on a car that has been in northern IL its whole life.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">I forgot to mention I'll be using hondata.
You only have to do it once
Another reason I would do it. I wouldnt trust that old CRX fuel pump. It has been in there how long? The car I talked about above was a 2000 ITR
</TD></TR></TABLE>You only have to do it once
I had a simalar experence with my stock fuel pump leaning out on the top end. Changed to a walbro 255lph and problem solved.
With the set up mentioned in the first post I would say that the stock fuel pump would be at its limit. And if it is the stock crx pump it would be pretty old.
i used a stock fuel pump in my b18c JRSC CRX with no problems for a year then i switched it out once i went turbo Switching the fuel pump is not hard at all in a crx. Just make sure you run your car almost out of gas. it didnt take long at all
I just put a walbro in my DA on jackstands, it's really not a big deal. Just get the car up high enough so you can drop the tank on your belly and roll out on the creeper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls »</TD></TR><TR><TD CLASS="quote">well i think you are gonna make more than 200HP on 8PSI with a T3/T4.
so dont chance it, its not worth it...
or........do chance it and let us know what the breaking point was</TD></TR></TABLE>I'm really only running sping pressure. With a tial with the .5 bar spring I think it's 7.25 psi. I just said 8 to be fair
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">walbros are less than $100 and take about 15 minutes to install.....why the hell would you cheap out on something so inexpensive?? </TD></TR></TABLE>
because some people are cheap and lazy
Not saying that the OP is either of the above......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">
You'd have to be pretty cheap and lazy if you decided not to buy a Walbro. It has to be the easiest thing in the whole turbo setup to install and one the cheapest things too....
Breaking point is going to be different from car to car. Every car's wiring, alternator, battery, etc. is going to be different as far as conditions and working order
Not saying that the OP is either of the above...... </TD></TR></TABLE>bingo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si »</TD></TR><TR><TD CLASS="quote">15 minutes to install a fuel pump in a crx. Obviously you have never changed a ful pump in a crx.</TD></TR></TABLE>nope
edit: would have searched to see how hard it is, but the search function was all screwed up yesterday. Hence the creation of this thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si »</TD></TR><TR><TD CLASS="quote">15 minutes to install a fuel pump in a crx. Obviously you have never changed a ful pump in a crx.</TD></TR></TABLE>nopeedit: would have searched to see how hard it is, but the search function was all screwed up yesterday. Hence the creation of this thread
It is not to hard but I will take more like 2 hours. If you allow time for some of the pain in the butt thingsthat can go wrong.
I think your stock one should be fine for your d-series. When I posted before I thought you were runnig your t3/t4 on a b-series. What are the specs on the turbo anyways.
My stock pump did fine on by b16 till I put a bigger turbo and ramhorn mani. Then I upgraded to a walbro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>garrett T3/T4 AR .48 57 trim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Made 300 whp/300tq all day long for a year. Then got some bad gas and chumped a piston. </TD></TR></TABLE>
You sure it was bad gas?
