obd0 to obd1 help help help
Old Mar 5, 2007 | 10:32 PM
eg6koto's Avatar
Default obd0 to obd1 help help help
i got a obd0 motor but my car is obd1. how can i convert it into obd1?? is der any conversion for dat?? help plz..
Old Mar 5, 2007 | 11:10 PM
unknown0001's Avatar
Default Re: obd0 to obd1 help help help (eg6koto)
OBD is mainly sensor plugs and wiring, so you would need to mount in the engine into your car, get it bolted up then try to see if the connectors will plug into their appropriate locations, if they don't then you'll need to hop over to the auto wreckers and get the correct obd-1 engine side sensors
Old Mar 6, 2007 | 11:29 AM
HondaPartsHero's Avatar
Technical Hero
What motor do you have? Pretty much everything will plug up except the distributor, fuel injectors, fan switch, and Oxgen sensor. Just swap your injectors over to the OBD0 motor, you will have to use an OBD1 distributor, and if your block has a tapped place on the back for the fan switch just swap it over, otherwise you have to wire it from the thermostat housing to the back of the block. And just use your 4 wire O2 sensor.
NhoedeEJ1
Aug 20, 2012 01:40 PM
MniMeHatch89
May 24, 2007 09:10 PM
Beau Gotti
Feb 8, 2006 12:35 PM
LD_EGSICK
May 8, 2004 09:51 PM
7rrivera7
Nov 9, 2002 06:38 AM
