Boosted RSX with Return Fuel system
im woking on a rsx-s with a 35r on it and i have the walbro 255 fuel pump in there with a return fule system installed but the pump doesnt seem toput any pressure out and isnt getting anything to the rail at all, anyone have any ideas?
1. Check voltage to pump. Can you hear it running when you key on?
2. Make sure inlet screen in pump / inlet filter isn't clogged.
3. Make sure outlet filter isn't clogged.
4. Make sure outlet of fuel rail is plumbed to the inlet of the P.R.
5. Make sure outlet of P.R. is plumbed back to fuel tank.
6. Make sure boost/vacuum reference line is connected to your P.R.
7. If you have an adjustable P.R., have you turned in the adjustment screw? Typically they are sold without the screw engaged = no pressure. Get a PSI gauge to set & monitor the fuel pressure at the valve.
If all that checks out and you don't have fuel spraying all over your driveway or garage, I can't think of anything else.
iBrandon
Feb 17, 2005 02:33 PM
Dominic-CTR
Oct 24, 2004 04:08 AM
