Oil consumption while at wot???
Old Mar 5, 2007 | 08:42 PM
IntegraType-R's Avatar
Default Oil consumption while at wot???
Well, the car has always been blowing alittle smoke here and there while WOT, but nothing major its just got to where that smoke is annoying, and its actually gotten alittle bit worst..
I can drive normal, and down shift and hit vtec and no smoke, its only at around 6-9k that blue smoke is noticeable from my exhaust..
I have no leaks, CR test is around 260psi across the board, Should i do a leakdown test to see? Valvestem seals are brand new, i just redid the head about 2 months ago.. There's no leaks and to be honest with you, i haven't really lost any oil, infact i lost more oil in a 400 mile trip, then i did racing a whole night..
The walls of my block are pretty great condition, minor, minor scuffing but i'm sure thats normal, car is pretty well tuned as well by me, on crome pro, its 13.0 WOT AFR..and its just annoying.. I do have a breather setup on the car, but its from the pcv(black box) to a catch can, then into the intake manifold.
Hardly any oil in that, and also in the manifold there's no oil either.. There's no leaks.. I'm thinking its my oil control rings but it wouldn't be this much oil..and i dont think it would hold compression that good either..
I'm still getting some major, major crankcase pressure which i think is creating blow by, i can whip off my oil pan and if i get on it enough some oil tends to "worm" out the sides..not alot and it doesn't do it perfusly just small, small amount... Any idea guys? i'm stuck really lol..
Old Mar 5, 2007 | 09:58 PM
PyroProblem's Avatar
Default Re: Oil consumption while at wot??? (IntegraType-R)
sounds like high crankcase pressures like you said.
Having the catch can routed after th factory black box is not going to help much. I think you need to vent the block more like the Endyn setup or even the vented valvecover setup.
Too much crankcase will definately cause blowby.And blowby will definately cause excessive crankcase pressure.
Compression rings can be perfect but if the oil rings are bad,youre gonna burn oil...
Good luck
Old Mar 6, 2007 | 04:36 AM
Default Re: Oil consumption while at wot??? (PyroProblem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">sounds like high crankcase pressures like you said.
Good luck </TD></TR></TABLE>
Thx you an answer i've been waiting to hear, i've had this in the back of my head for months now..What would you suggest..??
Because as it stands right now i want to get rid of this problem.. The car is goint o burn oil, its a 97 usdm type-r motor , vtec motors burn oil i know this..but lately it doesn't do it alot..whats a good way of solving this problem??
Old Mar 6, 2007 | 12:33 PM
bump?
Old Mar 8, 2007 | 07:35 PM
Default Re: (IntegraType-R)
I picked up a catch can from Endyn. You vent the block in two places and it seems to work very well.
I only had mine on for a week before my headgasket blew and i pulled the motor.
It did seem to rev easier or maybe it was just in my mind.
For me, it was an oil pan gasket that kept leaking. Could not figure it out until I related my oil consumption issues and learned about crankcase pressures!
Old Mar 9, 2007 | 09:36 AM
Default Re: (PyroProblem)
i think i'ma go ahead and do this too.
Old Mar 9, 2007 | 12:28 PM
poptik's Avatar
take it apart, replace valves/pistons
Old Mar 9, 2007 | 12:31 PM
Default Re: (poptik)
uh ya ok.. the head just got fully built like 4 months ago..no thx my head alone is probably worth 1200+
SidPM-EG6
10
Dec 27, 2015 05:53 AM
Prudz_lude
Oct 27, 2015 09:12 AM
IntegraType-R
Mar 7, 2007 09:55 AM
Torlie
May 26, 2006 06:17 AM
vxnine
18
Oct 11, 2003 07:24 PM
