AFC NEO what exactly does it do? (searched)
Old Mar 5, 2007 | 07:40 PM
itr1235's Avatar
Default AFC NEO what exactly does it do? (searched)
i have a stock r and someone got one for cheap, what exactly does it do?
Old Mar 5, 2007 | 07:43 PM
neo_'s Avatar
Default Re: AFC NEO what exactly does it do? (itr1235)
Same thing that a regular (V)AFC does but slightly more options, and better looking display.
Crome/Hondata/etc.. Are usually a better option anyway.
Old Mar 5, 2007 | 07:57 PM
MidwestSiR's Avatar
Default Re: AFC NEO what exactly does it do? (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Same thing that a regular (V)AFC does but slightly more options, and better looking display.
Crome/Hondata/etc.. Are usually a better option anyway.</TD></TR></TABLE>
basically what he said.. it's a smaller unit with a few more options. How cheap is cheap?
Old Mar 5, 2007 | 08:15 PM
itr1235's Avatar
2 bills
"Same thing that a regular (V)AFC does but slightly more options, and better looking display" to quote but i don`t know about either.
what do they do and is it any benefit for a stock r?
Old Mar 5, 2007 | 08:20 PM
MattyP's Avatar
You would spend your money better using Crome,uberdata,or hondata...as the other's said...The neo is the same thing as the other,just a couple more options and a color display
Old Mar 5, 2007 | 08:33 PM
itr1235's Avatar
Default Re: (MattyP)
sorry man,i dont know what benefits these products do. the web site does not say what it does to the vehicle
Old Mar 5, 2007 | 08:42 PM
neo_'s Avatar
Default Re: (itr1235)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1235 &raquo;</TD></TR><TR><TD CLASS="quote">sorry man,i dont know what benefits these products do. the web site does not say what it does to the vehicle</TD></TR></TABLE>
Seems like you don't know the basics. the AFC is a piggy Back controller which allows stock ECUs to do things that they normally can't do, like run larger injectors or deal with boost. You can adjust the air/fuel ratios, VTEC crossover, timing and etc.. Why piggy back (VAFC, etc..) controllers suck: Remember that piggyback controllers work by altering sensor signals before they get to the ECU.
Most of the time, the primary signal being messed with is the Map Sensor. This is critically important in a Speed Density car. The Map Sensor is used by the ECU to guess how much air is going into the car, and therefore how much fuel to supply in order to match airflow. When you "lean" out a car with an AFC, you are simply decreasing the Map Sensor signal - the ECU responds to the decrease in manifold pressure by supplying less fuel. When you "richen" a car with an AFC, you are simply increasing the Map Sensor signal - the ECU responds to the increase in manifold pressure by supplying more fuel.
The change in fueling happens for a reason: if you look at a fuel table, Map Sensor values correspond with columns. When you increase or decrease the signal from the Map Sensor, you are simply making the ECU use a different column than it originally would have used. (see Understanding Maps if you need some help understanding reading Fuel and Ign tables)
But wait, isn't the Map Sensor used for determining ignition requirements too? When you "lean" out a car with a Piggy Back, you also in all likelyhood advanced timing. When you "richen" a car with a Piggy Back, you also in all likelyhood retarded timing. Look at trends horizontally (as MAP changes) in an ignition table, and you will see why this happens. This helps explain why so many boosted cars running on the "AFC hack" have issues due to excessive ignition advance.
The bottom line: Piggy Back Controllers suck because you cannot independently adjust fuel and ignition. Any changes to fueling will produce a change in ignition too, and often this is undesirable. Source taken from Phearable.
Modified by neo_ at 4:59 PM 3/6/2007
PrinceAli132's Avatar
The products mentioned are engine management/tuning software. Which are used to adjust fuel, timming, vtec engagement, etc.
Neo_ just walked all over my response.
Ali
Old Mar 5, 2007 | 08:43 PM
MidwestSiR's Avatar
neo: did you write the book for Apex'i?
Old Mar 5, 2007 | 08:45 PM
itr1235's Avatar
thanks neo, i understand now.cheers
neo_'s Avatar
Old Mar 5, 2007 | 08:47 PM
MattyP's Avatar
It's a method of tuning the car...but not something you just want to hook up your self if you dont know anything about it...i've seen people put these in their car and just start pushing buttons... Maybe this will help a little...https://honda-tech.com/zerothread?id=1578524
-edit- Neo just typed all that while i just typed that...dam, he walked all over mine as well.... P.S. I'll stick with my chipped ECU
Old Mar 6, 2007 | 10:49 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
great WU Neo
Old Mar 6, 2007 | 12:39 PM
doood's Avatar
been there done that
Default Re: (PrinceAli132)
did someone copy and paste from http://www.phearable.net/tech/....html
Old Mar 6, 2007 | 12:50 PM
neo_'s Avatar
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">did someone copy and paste from http://www.phearable.net/tech/....html
Obviously, thats my ITR's tuner.
BTW, its from PGMFI. I never took credit for that.
Modified by neo_ at 5:01 PM 3/6/2007
Old Mar 6, 2007 | 01:23 PM
doood's Avatar
Default Re: (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Obviously, thats my ITR's tuner.
Modified by neo_ at 5:01 PM 3/6/2007</TD></TR></TABLE>
just poking fun
Boarderx192
Feb 4, 2006 02:34 PM
mdj_ge
Oct 12, 2004 03:16 PM
sh-ef
Jun 28, 2004 07:15 AM
sledgehammer
Feb 29, 2004 07:21 AM
Elkins911
Nov 16, 2003 03:55 PM
