Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
BC Stage 2 N/A Cams
Old Mar 5, 2007 | 07:28 PM
silvsi24's Avatar
Default BC Stage 2 N/A Cams
Is anyone running or is planing on running the crower stage 2 cams for N/A?, Just curious because im trying to find my footing with the whole valvetrain/cams, reflash,E/H/I set up i saw the other thread started by type x which helped alot but any other information or thoughts would help
Old Mar 5, 2007 | 07:57 PM
blue2ksi's Avatar
i think everyone is hesitant becauase there is no tuning available except a basic re-flash... sigh
Old Mar 5, 2007 | 08:36 PM
newdanger's Avatar
in due time hondata will release k-pro for the FG/FA's and all hell will break loose... i can't wait!!
Old Mar 6, 2007 | 09:48 AM
silvsi24's Avatar
Default Re: (newdanger)
yeah but these cams work with the hondata reflash
Old Mar 6, 2007 | 10:04 AM
blue2ksi's Avatar
Default Re: (silvsi24)
yes they will work but a reflash is limited in the ability to tune, therefore the potential of the cams will not be met fully.
Old May 24, 2007 | 11:57 AM
seed2harvest's Avatar
* B A N N E D *
any updates on this shizzle?
i was looking to buy new cams, cam gears to go along with the v-tec controller im gunna pick up.........
Old May 24, 2007 | 12:03 PM
IT GUY's Avatar
Default Re: (seed2harvest)
vtec controller?!? why?
Old May 24, 2007 | 12:06 PM
* B A N N E D *
to engage it sooner....
theres a few features i like about it.
Old May 24, 2007 | 12:09 PM
* B A N N E D *
For optimal fuel control - VTEC engagement control from 3000-7000 RPM in 100 RPM increments - 12 point fuel control for LOW and HIGH VTEC maps (total of 24 points) - i-VTEC compliant - Monitor i-VTEC VVT movement in real time - Password protection - Red LED light indicated cam switchover point - EEPROM chip for maximum data storage - VTEC Match/Unmatch correction for smooth VTEC engagement modification
Old May 24, 2007 | 12:13 PM
Type X's Avatar
Default Re: BC Stage 2 N/A Cams (silvsi24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvsi24 &raquo;</TD></TR><TR><TD CLASS="quote">Is anyone running or is planing on running the crower stage 2 cams for N/A?, Just curious because im trying to find my footing with the whole valvetrain/cams, reflash,E/H/I set up i saw the other thread started by type x which helped alot but any other information or thoughts would help </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2ksi &raquo;</TD></TR><TR><TD CLASS="quote">yes they will work but a reflash is limited in the ability to tune, therefore the potential of the cams will not be met fully.</TD></TR></TABLE>
After researching BC cams with some shops that build complete race cars and sell various products.
I was notified that BC cams have a tendency to crack.
so they were deleted off my list of things to look at
& added to my recycle bin.
Old May 24, 2007 | 12:17 PM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seed2harvest &raquo;</TD></TR><TR><TD CLASS="quote">any updates on this shizzle?
i was looking to buy new cams, cam gears to go along with the v-tec controller im gunna pick up.........</TD></TR></TABLE>
BTW.. won't aftermarket cam gears eliminate i-vtec function? I know the exhaust can be changed to an adjustable gear, but if you change the intake you lose computer control of the cam timing
Old May 24, 2007 | 12:50 PM
* B A N N E D *
word. ill look into that. im still in the thinking process while i stack my chips up........
ratski
Engine Machining & Assembly
Jan 19, 2019 09:28 PM
preludebeast94
Dec 8, 2007 05:41 PM
digital sol
Apr 26, 2006 10:42 AM
bunnyrabbit
Jun 16, 2004 06:34 PM
t3to4e
Jan 17, 2004 08:31 AM
