dsm 450 install? (already did search and it hasnt been awnsered)
Old Mar 5, 2007 | 05:23 PM
mikegeezy's Avatar
Default dsm 450 install? (already did search and it hasnt been awnsered)
so my question is do i take out the bottom seals the hard plastic ones and leave them out? i already drilled the top seals the rubber ones and they fit on the injectors perfectly but i am unable to put them in the manifold becuse of the bottom hard plastic seal. if i take the bottom seal out i can put the injectors in and it looks good but someone was saying that it may come out under boost is that correct or whats the deal thanx
Old Mar 5, 2007 | 05:29 PM
Snafubmx234's Avatar
The only seal you have to do anything to is the OEM Honda washer into the intake manifold. You can either use some lube and force them in, or use a Dremel so they fit the DSM 450's. All other seals should be be left alone.
Old Mar 5, 2007 | 05:50 PM
mikegeezy's Avatar
Default Re: (Snafubmx234)
yes there are two seals that sit in the mani the bottom one (hard plastic) and top one that goes around the injector (rubber) i dremeled the rubber one so that it will fit around the injector but they will not go in the intake manifold with the bottom seal (hard plastic) one still in the manifold but if it take the plastic ones out then they fit.
Old Mar 5, 2007 | 06:02 PM
h22sedan's Avatar
Default Re: (mikegeezy)
BUMP for some answers.
I also prepped my set of DSM 450's with OEM o-rings and I noticed the same fitment issue. I'd think leaving the hard plastic ring out is ok?
Old Mar 5, 2007 | 06:19 PM
Snail Tuning's Avatar
Default Re: (h22sedan)
if you leave the bottom seal out your car will run like crap and have a vacume leak. i use factory honda orings for the top and have never had any problems. you shouldn't be messing with the fuel rail side orings. the bottom seals should be lubed and they will fit very tigtly.
Old Mar 5, 2007 | 06:39 PM
da_dude's Avatar
Are you talking about the 3 hard plastic spacer that the fuel rail sit on? Or the bottom O rings that goes on the intake manifold?
Old Mar 5, 2007 | 06:44 PM
mikegeezy's Avatar
Default Re: (turb20_vtec)
i am talking about the hard platic rings that sit inside the injector holes on the intake mani. i already drilled the rubber ones that fit over the injector but they will not fit with those hard plastic rings in the holes.
Old Mar 5, 2007 | 08:21 PM
HiProfile's Avatar
I just tossed my age-hardened seals and used whats essentially a ring of rubber hose, although its a bit overkill - viton-f synthetic rubber. I think the dimensions are 5/8"x7/8", its perfect for the manifold, but a bit tight for at least dsm's and deka injectors. It also solved the height issue. I could always make up more sets, and have o-rings for the tops if yours are worn
Old Mar 5, 2007 | 08:26 PM
da_dude's Avatar
I have use it without the 3 hard plastic rings before and it was fine. Just make sure you don't over tighten the fuel rail down.
Old Mar 5, 2007 | 08:51 PM
LoseRPunKx182's Avatar
no u dont need those. they're for the dsm...just bore ur honda seals and put them in.
Old Mar 5, 2007 | 09:10 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (LoseRPunKx182)
Will dsm seals fit in the intake manifold or is the outside diameter of them the wrong size?
importdude2000
Apr 20, 2006 12:50 PM
16STCRX
Oct 19, 2003 11:07 PM
djnikko
Oct 13, 2003 06:58 PM
HXMan
Jun 2, 2002 11:08 AM
Mikey3000
Mar 19, 2002 11:21 AM
