2003 Accord CEL **need help**
Old Mar 5, 2007 | 05:17 PM
SlowSOHC-T's Avatar
Default 2003 Accord CEL **need help**
Ok I have a 2003 Honda Accord and about a week ago the CEL came on the ecu keep going into and I call "limp mode". Car would rev over 2500 rpms and just ran like crap. So i had the motor scanned and they said it was bank 2 o2 sensor. So I changed it and it was obvious that the other was bad and went ahead and changed the plugs as well w/ were horrible looking. So after that the motor ran good for about 15min and than bam the CEL kicked back on. So I turned around and had it scanned. Its now pulling error code:
Code 2646: A Rocker Arm Actuator System Stuck Off
What the hell is that and how the hell do I fix it? I'm new to the K-series motors so please someone help me out here...
Old Mar 5, 2007 | 05:57 PM
Echo7847's Avatar
Default Re: 2003 Accord CEL **need help** (IWANTAHB)
p2646 is vtec oil pressure switch circuit low voltage. (4cyl accord)
since you're using a generic scanner it wont tell you. I've had one of these before, I replaced the oil pressure switch and cleared the dtc, test drove and everythign was good. Theres an old service news about it from honda.
Old Mar 6, 2007 | 04:35 AM
SlowSOHC-T's Avatar
Default Re: 2003 Accord CEL **need help** (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">p2646 is vtec oil pressure switch circuit low voltage. (4cyl accord)
since you're using a generic scanner it wont tell you. I've had one of these before, I replaced the oil pressure switch and cleared the dtc, test drove and everythign was good. Theres an old service news about it from honda.</TD></TR></TABLE>
Do you have a link?
Old Mar 6, 2007 | 10:14 AM
SlowSOHC-T's Avatar
TTT
JEBurnett
Dec 10, 2018 12:50 PM
Juan_Pablo
Jun 25, 2013 12:50 AM
termite1r
Oct 24, 2012 07:31 AM
f22vtec1
Apr 21, 2011 10:49 AM
SlowSOHC-T
Mar 10, 2007 04:36 PM
