92 civic shell/16 foot trailer
Old Mar 5, 2007 | 04:27 PM
simplecivic's Avatar
Default 92 civic shell/16 foot trailer
92 civic hatch shell
6 point roll cage
omp front seats
omp steering wheel
monter tacd
oil gauge
boost gauge
civic audio pocket
tokico 5 way ajustable
skunk coil overs
skunk drag spings in rear
skunk camber kit ( upper arm kit )
99 civic si rear disc conversion
extended front wheel studs
cardon duck bill
i do have a bumper that is the same color, the one in the pic is cut for a defuser
car does have head lights just not in pics. im sure i left more sutff out. the car is a mess because i was storing stuff in it
16 foot closed deck trailer. im guessing trailer has less them 1000 miles on it. 3 boxes on the front, wnech, and electric brakes.
92 hatch $2500
trailer $2500
you can email me at hondahtchbksi@hotmail.com.
Old Mar 6, 2007 | 03:10 AM
UNKNOWN_MEMBER's Avatar
Default Re: 92 civic shell/16 foot trailer (simplecivic)
man i would love to pick that shell up only if u were local
Old Mar 10, 2007 | 11:09 AM
Default Re: 92 civic shell/16 foot trailer (UNKNOWN_MEMBER)
bump
Old Mar 11, 2007 | 12:42 PM
bump
Old Mar 12, 2007 | 05:37 PM
bump
Old Mar 14, 2007 | 04:25 AM
monEmakindave's Avatar
bumpin for a good deal.
Old Mar 14, 2007 | 04:35 PM
Default Re: 92 civic shell/16 foot trailer (monEmakindave)
bump
Old Mar 15, 2007 | 01:16 PM
bump
Old Mar 16, 2007 | 04:03 AM
good seller
Old Mar 16, 2007 | 12:50 PM
bump
Old Mar 17, 2007 | 10:37 AM
SwappedTURBOegg's Avatar
bump for a awesome car
Old Mar 18, 2007 | 06:03 PM
Default Re: (SwappedTURBOegg)
bump
Old Mar 22, 2007 | 01:02 PM
Default Re: (simplecivic)
bump
Old Mar 22, 2007 | 10:11 PM
sleepless247's Avatar
Your not interested in any trades are you
Old Mar 23, 2007 | 03:03 AM
Default Re: (sleepless247)
not realy but what are you looking to trade. bump
Old Mar 23, 2007 | 11:02 AM
I've got a 98 Integra GSR with the following done to it.
Well the car has a Skunk2 Pro Intake Manifold, BBK 65mm Throttle Body, 01 Integra Type R cams, P73 ECU, JDM 4-1 header w/2.5" collector, 2.5" magnaflow cat, 18" magnaflow resonator, 5x8 oval universal magnaflow muffler, custom 2.5" cat back exhaust, full eibach pro suspension kit, TMW stage 1 short shifter and prothane bushings, AEM Fuel Pressure regulator, JDM Civic Type R LSD trans, stage 3 Exedy clutch fidanza 8lb flywheel and OEM Honda throwout bearing.
I also just did a full tune up and timing belt less than 5000 miles ago. I used all OEM parts for the water pump, alt,p/s, and a/c belts, timing belt tensioner, spark plugs, fuel filter, NGK vlue spark plug wires, Brand new Distributor, and I used a Toda Power Timing Belt. I also did brakes on the car all around with Brembo blank rotors with Hawk HPS pads.
The car does need all four wheel bearings replaced which I do have. I am going to install them as soon as I pull the car out of storage. I also need to replace the current high flow cat thats on the car. Magnaflow sent me an OBD1 cat instead of an OBD2 cat. The OBD1 cat sets a CEL but that will be taken care of once I replace it.
Old Mar 23, 2007 | 05:36 PM
bump
Old Mar 26, 2007 | 06:08 PM
bump
Old Apr 3, 2007 | 04:22 PM
bump
Old Apr 7, 2007 | 05:40 PM
GuidoFace21's Avatar
you still have the civic?
Old Apr 8, 2007 | 04:47 AM
Default Re: (GuidoFace21)
bump yes
Old Apr 8, 2007 | 05:57 PM
1700anddroping's Avatar
good guy here fella's
Old Apr 8, 2007 | 06:08 PM
Default Re: (1700anddroping)
lol bump
Old Apr 15, 2007 | 05:42 PM
New Dimensions's Avatar
still have the shell?
Old Apr 16, 2007 | 04:04 PM
Default Re: (New Dimensions)
yes bump
