door panel removal
Old Mar 5, 2007 | 03:23 PM
cityslicker1606's Avatar
Default door panel removal
my power window are slow as hell so i want to grease them up, can someone tell me how to take the damn door panel off, i didnt know there was so many hidden screws.(1992 honda accord ex)
Old Mar 5, 2007 | 03:31 PM
hondadude's Avatar
Default Re: door panel removal (cityslicker1606)
clean out the window run channel, then spray some silicone in there and run the window up and down. or you can smear in some Shintsu grease where the window rubs the run channel, again cycle the window to work it into the rubber.
Door panel removal;
Screw for the door latch, and unhook the latch rod; one screw in the armrest pocket, 3 screws across the lower area of the armrest. don't remember if there are screws thru those speaker grills, maybe 3 down there.
then grab the lower rear part of the panel and yank it.
Old Mar 5, 2007 | 03:32 PM
Default Re: door panel removal (hondadude)
ok thanks
Old Mar 5, 2007 | 03:35 PM
Grandhustleman86's Avatar
there is one in the arm rest(theres a small cover over it pop it off)....there is another at the lower rear corner at the end of the paperwork pocket(also has a cover)....last one is in the door handle....after that you can pull it off....after all the screws are out it is held on by plastic clips....just pops right off....
FYI-4dr model
casper.hughes
Oct 12, 2008 06:33 PM
Kataku2K3
Feb 11, 2007 02:06 PM
TryinToHelpSis
Jun 5, 2003 04:15 PM
all420
Jun 1, 2003 05:53 PM
