reverse lights always on?
Old Mar 5, 2007 | 12:02 PM
russianswty's Avatar
Default reverse lights always on?
Ok so I have a 95 ex accord and i have this problem, while the bulbs are in the socket
the reverse lights are always on.
I tried disconecting my reverse light switch, which turns them of, but then doesn't work
when I put it in reverse. Obviously.
I'm using the 1156 bulb. I looked around (didnt strip the car or any thing) but I didnt
find any of the wires being tampered with.
So I have no idea.
Old Mar 5, 2007 | 01:36 PM
sony224422's Avatar
Default Re: reverse lights always on? (russianswty)
are they in right? can't you put those ones in backwards?
what happens when you put the car in reverse when they already are on.. do they go off
Old Mar 5, 2007 | 02:13 PM
hondadude's Avatar
Well if the lights don't work at all with the switch disconnected that would lead me to believe the switch has shorted to ground.
Old Mar 6, 2007 | 10:39 AM
Default Re: reverse lights always on? (hondadude)
theres only one way to put the bulbs in its the "right way" lol
but seriesly, unless you jam it and brake something, it only goes in one way.
But when the bulb is in the socket no matter if my lights are on, its in first or reverse
it stays on and doesn't do anything.
So how could I have a short in my switch, should I just remove it and install a new one.
Ive never heard of a reverse switch going bad.
Old Mar 6, 2007 | 10:42 AM
Tech-Nics's Avatar
sure sounds like wiring problem or a short in the relay switch that kicks on the reverse lights on when you put your shifter into reverse. there should be no power heading to the reverse lights unless the transmission is set in reverse.
Old Mar 6, 2007 | 12:13 PM
Default Re: (Tech-Nics)
so what or how do I exactly check?
So it has constant power for some reason
JDMJUNKIEMONKIE
Oct 25, 2009 02:17 AM
studlete
Aug 26, 2009 10:22 AM
stupidwhitecat
Nov 5, 2005 04:26 AM
