installing front balljoint camber kit?
Old Mar 5, 2007 | 11:16 AM
russianswty's Avatar
Default installing front balljoint camber kit?
has any one installed on of these on there accord? Do those kits work good?
Also how the hell do I get my original ball joint out of the uca?
Old Mar 5, 2007 | 03:10 PM
hondadude's Avatar
Default Re: installing front balljoint camber kit? (russianswty)
the camber adjusters go where the upper control arm mounts to the body, the ball joint doesn't have to be removed.
Old Mar 6, 2007 | 10:36 AM
Default Re: installing front balljoint camber kit? (hondadude)
ok there are 2 kinds of camber kit.
First one you have the upper control arm that has the adjustable part
that attached to the frame, and then you have option two.
Where you use the ball joint camber kit
Old Mar 6, 2007 | 05:21 PM
loup05's Avatar
i have heard and seen some of these i am also curious because i was thinking of going with the ball joint camber kit
Modified by loup05 at 4:20 AM 3/7/2007
Old Mar 6, 2007 | 07:45 PM
hb_guy's Avatar
Default Re: installing front balljoint camber kit? (loup05)
post some pics of the one YOU have so we can see.
Old Mar 6, 2007 | 10:42 PM
http://www.inlinefour.com/spccamberkit.html
Old Mar 7, 2007 | 03:20 AM
loup05's Avatar
thats exacly the one i was talking about
Old Mar 7, 2007 | 11:27 AM
ok does anybody know how to get that damn ball joint out of the lower control arm.
Is it pressed in or something? Do I need to press it out. Is there any tricks
Come on guys
Old Mar 7, 2007 | 12:18 PM
hmj88hb's Avatar
I haven't those before but I believe they're pressed out. I in the process af changing to the adjustable ball joint. How much is your car lowered?
hmj88hb's Avatar
Default Re: installing front balljoint camber kit? (hmj88hb)
Escuse to errors
Old Mar 9, 2007 | 10:26 PM
its pretty low, the tires has maybe a 1/4 in between the wheel and the fender
88CRXJ
13
Sep 30, 2009 09:35 PM
chatman_55
Apr 5, 2009 01:34 PM
AdReNaLiN
Oct 17, 2008 12:00 AM
turbotime
Apr 14, 2005 09:00 AM
