obd0-obd1 conversion Help
Old Mar 5, 2007 | 10:24 AM
turboteg86's Avatar
Default obd0-obd1 conversion Help
Never done the conversion before. i got a 90 Integra LS w/ a 97 B20b turbo motor and am converting over to obd1. Got the distributor,4 wire o2 sensor, conversion harness and a p75 obd1 ecu. Was wondering if anyone got step by step instructions on how to do it or know a website that would. Any help I can get would be really appreciated. Pics would help also if anyone has it.Thanks.
Old Mar 5, 2007 | 11:41 AM
devnull's Avatar
If you got the conversion harness, you need only convert the sensor plugs and injectors. The plugs is cut and crimp (or solder). The injectors is a little more detailed as you remove the resistor box and get a junction box where four wires will go from to the injectors, and yes you can keep the old injectors if you wish and bypass that step. There is a wire diagram in the motor swap forum with a full detail of the O2 and other things.
Old Mar 5, 2007 | 04:51 PM
Blown90hatcH's Avatar
Default Re: obd0-obd1 conversion Help (turboteg86)
http://www.rywire.com
They have everything either included with their kit or can make it all plug and play.
jacoblytle
Engine Management and Tuning
Jun 25, 2014 07:56 AM
rexbooming
May 21, 2012 03:54 PM
Dee A Nine
Dec 7, 2004 08:36 PM
electric_rex
Sep 21, 2004 09:58 AM
B20Monster
Feb 3, 2004 08:11 PM
