Part number request: B series NGK spark plug 500+whp
I usually order BKR7E for my turbo setups, but I would like to go with a 8 heat range. BKR8E doesnt exist.
Can somebody provide some part numbers for me? thanks.
bkr8e-ix is the iridum version, they work very well.. i use em all the time. if its a street car thats what i recomend, they hold up alot longer than the standard ones, and they are resistor type. depending on the ign system you use you must have resistor type plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">bkr8e-ix is the iridum version, they work very well.. i use em all the time. if its a street car thats what i recomend, they hold up alot longer than the standard ones, and they are resistor type. depending on the ign system you use you must have resistor type plugs.</TD></TR></TABLE>
im running stock ignition. i ordered the 5671A-8s due to previous advice. its not a daily car - weekend and track only so i hope i will be fine. thanks for the info.
I know it's beaten to death but... really.. i have d series motor, do i use zr or br spark plugs?!?!
reignofchaos
Aug 1, 2003 08:30 PM
