Surface rust on final drive
Old Mar 5, 2007 | 08:09 AM
MAFDARK's Avatar
Default Surface rust on final drive
I went to put together my new LSD today and i found some surface rust on my final drive. Its not bad, but i wanted to double check on what i should do.
would cleaning it up with wd40 and a wire brush be ok? or do i need to find a new one?
Old Mar 5, 2007 | 11:43 AM
devnull's Avatar
Take it to a machine shop and have it micro polished. I highly advise AGAINEST the wire brush.
Old Mar 5, 2007 | 01:16 PM
MAFDARK's Avatar
best idea ive heard. Thanks.
Old Mar 8, 2007 | 03:38 PM
deftonerider's Avatar
how did that rust, did any water work its way into your tranny
Old Mar 8, 2007 | 05:00 PM
MAFDARK's Avatar
No, i took out the diff to put in an LSD... couldnt get the bolts off for the final drive before i had to go back for college. My own fault.
Old Mar 9, 2007 | 11:05 AM
Gearspeed-Performance's Avatar
Default Re: (MAFDARK)
Well if the rust is bad enough to pit the gear surface I would toss it out. Its a snowball effect once rust has started and the pits will eventually get biger and bigger. It's important that the gear surfaces are even. That prevents it from clicking, whinning or desintigrating itself.
If its mild like you say...I would run it through a deburring process and check the outcome
Old Mar 9, 2007 | 11:12 AM
MAFDARK's Avatar
Thanks, it was very light. Just WD40 showed some results.
The machine shop beat blasted it and it looks great.
But hey, your gear speed. Ive been trying to get a price on a 3rd/4th syncro sleeve. Can you get me a price?
Jdc5
20
Dec 24, 2008 09:21 AM
671XxDaRkCyDexX
Aug 26, 2008 06:46 AM
Christian
Mar 25, 2003 09:17 PM
shipsaeki
Mar 20, 2003 05:48 PM
NightHawkC5
Feb 28, 2003 07:36 AM
