I need to hold the ignitor to drive my car?? what's wrong!
Old Mar 4, 2007 | 11:28 PM
pineapplemike's Avatar
Default I need to hold the ignitor to drive my car?? what's wrong!
i recently posted that i couldn't get my car to start...it seems like i can get the car running if i keep the ingnition on...I didn't drive more than 15 feet (I just had to move it from the middle of my drive way to the side.)
https://honda-tech.com/zerothread?id=1910966
__________________________________________________ ____
Hi I need some advice.
I have a 94 Integra. 163000 miles.
My car starts, and then turns off right away. I try to get the RPM's up after the car starts, but it dies right away.
The radio and my lights are running fine. I have half a tank of gas.
I changed my battery less than 4000 miles ago, changed my distributor cap 11,000 miles ago and my alternator and my distributor in 2000 (probably at 105K+ miles.)
Does anyone have an idea of what my problem is?
I did get a SMOG check 2 days ago. I checked my wires going into the distributor cap.
Thank for your help!
some ppl suggested that it was fuel pump.... ( i also haven't changed my fuel filter for 55-60K miles.)
does anyone have any other suggestions?
Old Mar 5, 2007 | 04:06 AM
daveedd357's Avatar
Default Re: I need to hold the ignitor to drive my car?? what's wrong! (pineapplemike)
You need the electric ignition switch that goes behind the lock cylinder.
Old Mar 6, 2007 | 02:47 PM
Darth_Accord90's Avatar
Sounds like you lost the hot/run side from your ignition switch. You
need to replace it, find it cheap on eBay.
NoItsNotHerEk9
Apr 20, 2011 05:36 PM
pineapplemike
Mar 28, 2007 08:24 PM
pineapplemike
Mar 3, 2007 09:54 AM
customx_
Dec 7, 2002 01:24 PM
