hatchback rear quarter window clips!!! really need help
Old Mar 4, 2007 | 11:16 PM
89hatcher's Avatar
Default hatchback rear quarter window clips!!! really need help
really need your help my clips that hold the window came loose and then when i tried to tighten it and it broke is there any way to fix it? and how do you remove it cause i might go to the junk yard and try to remove it. thanks in advance
Old Mar 4, 2007 | 11:38 PM
Got_EF8's Avatar
Default Re: hatchback rear quarter window clips!!! really need help (89hatcher)
take off the trim peace wich is held on by 2 screws after that you will see the glass with 3 more screws holding the window go to the junk yard and take them off and your window will be fixed
Old Mar 4, 2007 | 11:43 PM
89hatcher's Avatar
how do i fix this?
Old Mar 5, 2007 | 04:37 AM
danmdevries's Avatar
Default Re: (89hatcher)
Haha, I JUST figured out how to fix it on my car last night.
They're not available new from Honda, so you'll have to go junkyard hunting.
The clip that's misssing is a black plastic clip with a square metal nut in it. You'll need a small screwdriver/pick something like that, you have to rotate the nut to run parallel with the clip, and then it will slide out.
It's hard to explain, but you'll understand once you see it. The metal nut rotates in the plastic clip. You'll probably have to pull several of them to get a set that isn't cracked. I had to pull 6 to get 3 good clips.
Old Mar 5, 2007 | 08:51 AM
89hatcher's Avatar
Default Re: (danmdevries)
thank you so much. gonna go to the junk yard and take as much as i can.
91ed9
Mar 23, 2007 02:32 PM
Robo_Wop
Jul 28, 2006 07:01 AM
athoughts
Nov 28, 2005 04:47 PM
*Boostwerks*
Sep 13, 2002 08:06 PM
