HELP!!!!!!
Old Mar 4, 2007 | 04:42 PM
ImXposed's Avatar
Needs $$ for a Hooker
Default HELP!!!!!!
A hose on the throttle snapped off the connector ON the throttle body. how badly did we just expletive up? can we drive it till we pick up a new one???? any ideas on repair? WHAT did we break???
Old Mar 4, 2007 | 05:08 PM
ImXposed's Avatar
Default Re: HELP!!!!!! (ImXposed)
bump I gotta get an answer to this
Old Mar 4, 2007 | 05:35 PM
OG SHG_EM1's Avatar
more detail of ur problem and not sounding like ur talking to urself would help...from the pictures it looks like ur showing a hose up to a perfectly fine throttle body...is that a buddies throttle body and ur just showing us what u broke...more explanation before u start posting on HT
Old Mar 4, 2007 | 05:36 PM
OG SHG_EM1's Avatar
and it looks like ur missing a bolt on that throttle body...u might want to bolt that down or u could get some nasty vacuum leak
Old Mar 4, 2007 | 05:40 PM
ImXposed's Avatar
that was as we were taking it off. the hose was to be disconnected and doing so snapped something off, like a plug. my question is is WHAT is that hose for, and can I drive on it till I get it fixed? not missing any bolts. and btw, I actually asked some very distinct questions that you failed to answer.
Old Mar 4, 2007 | 06:00 PM
CJ_2Dr's Avatar
Default Re: (ImXposed)
i understood exactly what u said but unfortunately i do not kno what those hose do, they are for vacuum, but to what specifically, i dont kno
just to guess tho, i would say u would have a leak if u drove it like that and maybe bad idle. but u might need a new throttle body????? idk
good luck tho hope u get it fixed.
Old Mar 5, 2007 | 02:14 AM
sik96teg's Avatar
Default Re: (CJ_2Dr)
Well what's at the other end of the vacuum line map sensor? I'm geussing that's an obd1 throttle body?
Old Mar 5, 2007 | 08:44 AM
dnjuandmrrco's Avatar
Default Re: (sik96teg)
actualy its obd0 i figured its a vacume tube to control the idle controle valve being that it cant idle that is untill the ecu catches it and throwsa check engine light then it idles for a bout 30 seconds
tim73
Jul 13, 2012 03:52 PM
Randysi
Aug 14, 2011 05:18 PM
FG Two
Jun 14, 2005 10:12 AM
