battery light stayin on
Old Mar 4, 2007 | 03:15 PM
eg6madness's Avatar
Default battery light stayin on
is there anyway to check the alternator at home? i was driving and my battery light pop on. the care starts and all but dash lights are dim and cluster shut off about 10 mins after i turned on my headlights.
i know it is not the battery cuz i swapped it out for another.
is there anythign else it could be?
how can i check to see if the alternator works correctly?
Old Mar 4, 2007 | 04:42 PM
b16a4's Avatar
Default Re: battery light stayin on (eg6madness)
is the alternator belt on?
Old Mar 4, 2007 | 05:15 PM
Bjorn20's Avatar
does the battery light stay on after the engine starts?
dont remember the EXACT cause of that light staying on. But it has to do with a difference in voltage potentional in 2 circuits that cause it to stay on. If voltage is the same on both sides, no potentional they balance out, opening the circuit and the light goes out.
I want to say it has to do with the starter and battery, but i just dont remember i can look it up
Old Mar 4, 2007 | 05:21 PM
b16a4's Avatar
Default Re: battery light stayin on (Bjorn20)
also happened on my friends car when his alternator belt bursted
Old Mar 4, 2007 | 07:37 PM
dngr2myself's Avatar
Default Re: battery light stayin on (b16a4)
take a volt meter and put it on dc voltage. put the red lead on positive and black lead on negative. it should show anywhere from 13.7 to 14.2. if i am not mistaken though, the brake light would be on at the same time as the battery light if it is the alternator.
Bunny
May 24, 2009 01:16 PM
haywyre
Oct 9, 2008 12:27 PM
bleedblue94
May 20, 2006 07:57 PM
fe519
Sep 23, 2003 03:25 AM
