ctr tranny issue. need help asap
Old Mar 4, 2007 | 01:24 PM
dngr2myself's Avatar
Default ctr tranny issue. need help asap
Just purchased and swapped a b16b into an eg9. Pulled out of the garage fine in reverse and went into first gear fine. When I shifted into 2nd gear nothing. Motor just free revved. You can take your foot completely off the clutch pedal while in gear and step out of the car and no movement. Is there a way to tell if the lsd is the problem or the clutch without pulling the tranny. By the way clutch engaged revving the motor the speedo rises with rpms as if the car is moving. Any help would be greatly appreciated.
Old Mar 4, 2007 | 04:19 PM
Bense's Avatar
it sounds like a clutch issue
Old Mar 4, 2007 | 05:50 PM
daveedd357's Avatar
Default Re: ctr tranny issue. need help asap (dngr2myself)
check your axles. Sounds like your axle may have popped out
Old Mar 4, 2007 | 07:30 PM
Default Re: ctr tranny issue. need help asap (daveedd357)
pass side axle popped out. Thanks for the info.
Old Mar 5, 2007 | 09:58 AM
nokturnal_munkeeboy's Avatar
either ur second gear is gone, it might be the tranny you should get it check it out by a transmission tech. before you should worry bout clutch.
AaronJ
13
Nov 13, 2005 03:38 PM
-=MUGEN=-
Jul 14, 2005 11:28 AM
dorikingts
11
May 13, 2005 09:37 AM
locass316
May 13, 2003 08:53 AM
phatintegra
Mar 20, 2002 05:35 PM
