power from batery to trunk
hi guy I have a question for you all .. I just buy subb and I don't know how to pass the battery power wire where and how please ??? pics if possible
thx all... sorry for my english im french
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thetomshow »</TD></TR><TR><TD CLASS="quote">sorry for my english im french
that explains your avatar... oh well, no biggie
easiest way ive seen is passing the cable thru the boot for the steering column. its big, floopy, and theres a decent amount of room to manuver if you have the car on jack stands
</TD></TR></TABLE>that explains your avatar... oh well, no biggie
you want to run the power wire through a 'grommet' (its a rubber insulator in the firewall). You want to go throgh one of these, because drilling a hole in bare metal can short out the wire. Once you have the wire throgh the firewall, run it behind the driver side door sill, all the way to the trunk. Keep in mind, that you should use an appropriate sized fuse on the power wire, and put the fuse no more then 12 inches from the battery connection. (30cm if your in quebec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thetomshow »</TD></TR><TR><TD CLASS="quote">thx all iwas just asking for tip for passing the wire trough the rubber sealed hole now everything work
boum boum
great.
boum boum
</TD></TR></TABLE>great.
skypros
Mar 21, 2004 09:29 AM
