Knocking noise on acceleraton???
Old Mar 3, 2007 | 08:45 PM
stocky's Avatar
Default Knocking noise on acceleraton???
My car, H22A EG4 has a knocking noise.
The noise is present whilst the car is driving and also idle when I accelerate abrubtly. If I press the accelerator slowly, then it is all good. It is only when I push on it quickly from idle.
My initial thought was that it was a timing issue, I checked the timing with a timing gun and it is set at 15 degrees.
What could it be?
On a side note, the car has new spark plugs, oil, etc.
Old Mar 4, 2007 | 12:30 AM
stocky's Avatar
Default Re: Knocking noise on acceleraton??? (stocky)
Also, I retarded the timing the entire way and still this knocking exists.
Help?
Old Mar 6, 2007 | 03:09 PM
Darth_Accord90's Avatar
Bump up the octane, and see if that helps.
Old Mar 6, 2007 | 06:29 PM
Scott_Tucker's Avatar
It is possible that the knock is not coming from the engine. If one of the engine or transmission mounts were broken it could causing a metallic knocking noise under the conditions you mentioned.
Old Mar 6, 2007 | 07:29 PM
EKB18BPR3's Avatar
cracked header on a runner would sound like a knock everytime that cylinder fires...i only say that because my turbo manifold has a crack and sounds like that..
Old Mar 7, 2007 | 03:10 AM
stocky's Avatar
Default Re: Knocking noise on acceleraton??? (98B00STED)
It's weird, its definately coming from around the block/head area.
Its not the header because it only happens on occassion.
Also, im using 98RON fuel, the highest in Australia, it should be equivalent to your
93RdON fuel.
I will check the mounts though, thats a good suggestion.
It sounds exactly like pinging though .... ecu?
Old Mar 11, 2007 | 06:43 PM
deftonerider's Avatar
does it vibrate at all when knocking on hard acceleration?
if it does suspect an axle, cause often times in hybrid swaps the axles can be a tee bit to short or long which can make them vibrate and knock when you get on it
Old Mar 11, 2007 | 08:16 PM
dbiker207's Avatar
Default Re: (deftonerider)
it might be you have bad thrust brearings on the crank. what you hear is called crank walk if this is your problem. the knock will be most apperant when leaving stop signs aggresivly. check your crankshaft endplay.
Old Mar 12, 2007 | 06:16 PM
mrbgartner's Avatar
Try a cylinder leak-down test. I saw a H22 one time that had one bad exhaust valve stuck open causing a misfire.
Old Mar 13, 2007 | 05:14 AM
stocky's Avatar
Default Re: (dbiker207)
Def need to check clearances and run more tests
the knocking does not seem to be as apparent as a H23 i encountered that had bad bearings, these were rod bearings though.
Also, i forgot to mention that this car has a hondata. Could the timing maps cause this? KS is disabled on it.
Old Mar 15, 2007 | 06:23 AM
DAslammed's Avatar
Default Re: (stocky)
i had that same issue right after my timing belt broke! so make sure your timing belt is up to date...
KS3421
May 16, 2012 08:48 PM
d124g0n
Jul 21, 2005 06:29 PM
SteveeeO
Jun 19, 2003 12:35 PM
93SSPHatch
Jun 4, 2002 09:24 AM
