brake light and abs light on?
the E brake and abs light in my girlfriends 95 integra stays on for some reason even after she puts her E brake down. does anybody ever heard of this or knows how to fix it?
the abs light can come on for a number of reasons. the abs unit will tell you what is up if you open the access panel and look for blinking lights.... if its a 4-door its in the trunk on the passenger side, and in a 2-door its also on the passenger side but next to the back seat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronhume »</TD></TR><TR><TD CLASS="quote">the abs light can come on for a number of reasons. the abs unit will tell you what is up if you open the access panel and look for blinking lights.... if its a 4-door its in the trunk on the passenger side, and in a 2-door its also on the passenger side but next to the back seat.</TD></TR></TABLE>
For a DC or DB, you pull the ABS codes exactly the same way as you would a CEL. The ABS light will flash the codes. Check the FAQ thread for instructions and codes.
HONDA_TYPE_R
Nov 30, 2004 01:04 PM
