short shifter installation
Needs $$ for a Hooker
is it possible to instal my short shifter from the top and not the bottom??? I heard you have to remove the midsection from the exhaust and do it that way. true?
No not possible to install from the bottom
In order to get at the linkage to install it your have to unbolt or cut the heat shield. however you don't have to unbolt the exaust just plug the hangers off and it will hang down enough to do what you need to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_bizach »</TD></TR><TR><TD CLASS="quote">No not possible to install from the bottom
In order to get at the linkage to install it your have to unbolt or cut the heat shield. however you don't have to unbolt the exaust just plug the hangers off and it will hang down enough to do what you need to do</TD></TR></TABLE>
yeah, the headshield is a pain, but its gotta come out one way or the other, and the exhaust doesnt have to be removed, just makes the job ALOT easier.
No you need to get under and move the heat sheild. there are a few bolts that u are going to remove i wish i could of done mine just from the inside but you need to go in and under the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackturboteg »</TD></TR><TR><TD CLASS="quote">No you need to get under and move the heat sheild. there are a few bolts that u are going to remove i wish i could of done mine just from the inside but you need to go in and under the car.</TD></TR></TABLE>
awesome, thanks... i think ill do it tomorrow.
warchieft2k
Nov 24, 2006 09:02 PM
