JDM GSR Front brake pads are the same as?????????????
Old Mar 3, 2007 | 02:39 PM
93SIRII's Avatar
Default JDM GSR Front brake pads are the same as?????????????
does anyone know if the pads on a jdm gsr crossover to anything used in the usdm market. I have a jdm gsr front brake setup and I didn't know there was a difference between jdm gsr and usdm gsr, I found out the hard way my hawk hp plus won't fit. So I need to find an alternative.
Thanks in advance
Old Mar 3, 2007 | 07:04 PM
93SIRII's Avatar
anyone
Old Mar 3, 2007 | 07:30 PM
97ShLude's Avatar
Default Re: JDM GSR Front brake pads are the same as????????????? (93SIRII)
I thought that all Integra (exc. ITR) had the same front setup until like '98 where the GSR got bigger front calipers along with a bigger BMC, although I could be wrong. Why wont the pads fit, are they too big or too small?
Old Mar 3, 2007 | 10:07 PM
93SIRII's Avatar
the locating points at each end are too big and the pad itself is to small for the rotor
Old Mar 4, 2007 | 12:52 AM
BlueIntegraBoy's Avatar
The SiR-G has the same brakes as our GSR, LS, SE, GS, RS.
Old Mar 4, 2007 | 10:52 AM
93SIRII's Avatar
I know its the same as our gsr but what is the same as the jdm gsr thats what I need to know
Old Mar 5, 2007 | 12:36 AM
Default Re: (93SIRII)
JDM GSR = SiR-G
The only JDM Integra calipers that are different from ours is the 98 spec ITR. You sure you don't have EG6 calipers (uses 10.3" rotors like Integra), which then would use EX pads.
Old Mar 5, 2007 | 06:02 AM
Sleepy_Red_hatch's Avatar
Default Re: (BlueIntegraBoy)
you probably have JDM SiR brakes, which are the same size, just diffrent design, i think it was 94-95 civic EX coupe non-abs pads for it
Old Mar 5, 2007 | 04:51 PM
93SIRII's Avatar
do you know where I can get actual size diagrams? Hawk does not thave them.
Prox_Denali199
Mar 24, 2020 08:09 AM
Moonbus
May 13, 2004 05:57 PM
delux247
May 14, 2003 04:45 PM
Johnny_bdos
Apr 19, 2002 04:37 PM
