plz help
Old Mar 3, 2007 | 01:35 PM
zenon8890's Avatar
Default plz help
hi HT, i have a very wierd problem that just happened to me today, when i press the brake peddal to the floor the car dies, then i have to start it again, what is the problem?! its the first time it happens
Old Mar 3, 2007 | 01:55 PM
Perfectionist's Avatar
Default Re: plz help (zenon8890)
For a better chance of getting replies related to your problem, try re-titling your post with something like "engine dies when brakes applied".
Anyway, I would suspect a problem with your brake booster. It operates on engine vacuum. If the seal is blown, applying the brake creates a major vacuum leak that kills the engine. Try removing the vacuum hose that feeds the booster and plug the open end. CAREFULLY take it for a test drive remembering you don't have power assist on the brakes. If the engine doesn't stall, you've found the problem.
Old Mar 3, 2007 | 02:03 PM
zenon8890's Avatar
thanks, sorry i didnt add this up, but after i start it again it boggs alot
HondaVerno
Jun 29, 2008 08:28 AM
bullock
Nov 21, 2004 06:48 PM
racekar
Nov 7, 2004 06:16 PM
spender1326
Apr 30, 2004 06:09 PM
DragII
Apr 28, 2002 07:50 AM
