Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
v700 tire pressures
Old Mar 3, 2007 | 12:45 PM
vietnameeh's Avatar
Default v700 tire pressures
hello
ill be trying ecsta v700s tommorow...
and would like to know what pressure to start off with...
i was thinking to start with 40f 35r
this is on a 1997 honda civic with not much camber in the front ~2.0 or less
and ~1.0 on the rear
on my hankook rs2s i run 39f and 34r and it seems to work well
these are one 7 inch wide rims
the v700s seem to have really stiff sidewalls compared to my hankooks... does this mean i should run lower pressures?
tire size is also 205/50 15 thats on a 6.5 inch wide rim
im confused because there are soo many different ideas on what to start off with ive heard as low as 29 and then as high as 50
this is for autox , ill be using a chalk and hopefully a pyrometer if i can get a hold of one, but i dont want to be out ther with not enough air since sumone stole my air tank
thanx in advance
Old Mar 5, 2007 | 10:33 PM
95redeg6's Avatar
Default Re: v700 tire pressures (vietnameeh)
i heard 30 and 32....the porshe that i changed tires on were 29 31...there were also 245/45/17 in the fronts and 375/45/17 REARs...if that helps
Old Mar 5, 2007 | 10:41 PM
vietnameeh's Avatar
i figured it out... i ran 40 hot front and 33 rear... i was rolling in the a front a lil
Old Mar 5, 2007 | 11:31 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (vietnameeh)
i run 30 all around in mine.
Old Mar 6, 2007 | 01:11 AM
Gedupsound's Avatar
iiinteresting. i just ran our club's ice breaker event with my gsr. first time ever running a fwd in my gsr. i run 205/50R14's i think, i was maintaining 40psi hot up front, and started the rear at 45psi, and let it keep getting hotter in the rear up to 50psi. keep in my mind my car is bone stock. got top time in g stock.
Old Mar 6, 2007 | 01:20 AM
SnlpeR's Avatar
i think i was doing something like 42/40 hot on my prelude
Old Mar 6, 2007 | 01:07 PM
6spdKEG's Avatar
Default Re: (SnlpeR)
off of Tire rack for Hoosiers.. .
http://www.tirerack.com/tires/...d=144
VehicleSize Hot Pressure Cold Pressure
1800-2200 lbs 34-37+ ______26-31
2200-2600 lbs 35-38+______27-32
2600-3000 lbs 37-41+______27-32
over 3000 lbs 38-43+______27-33
Info from tire rack on V700s
Inflation Pressures
The V700 will work well on most cars with inflation pressures between 35 and 40 psi ("cold" inflation pressures for autocross use and "hot" inflation pressures for racing use). Cars that are light, well balanced and relatively easy on tires will find slightly lower pressures may work for them, while heavy, high horsepower cars that are generally harder on tires may find that they need slightly higher inflation pressures.
Generally adding air pressure in small increments (2 psi) to the tires on the end of the car that loses traction first works best. For example, if a car is understeering, add pressure to the front tires. If the car is oversteering, add pressure to the rear tires.
Old Mar 7, 2007 | 06:49 AM
6spdKEG's Avatar
Default Re: (6spdKEG)
Just wondering, when do those Ecsta V700s get slippery on the road courses?
Old Mar 7, 2007 | 08:20 AM
Ponyboy's Avatar
Painting Masterpieces
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6spdKEG &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering, when do those Ecsta V700s get slippery on the road courses?</TD></TR></TABLE>
When they overheat. Which has a bit to do with air pressure.
For the OP, I'd try contacting Kumho to get their recommended pressures first off. But it looks like the Tire Rack info is coming straight from Kumho so you may have your answer right there.
Old Mar 7, 2007 | 08:59 AM
6spdKEG's Avatar
Default Re: (Ponyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy &raquo;</TD></TR><TR><TD CLASS="quote">
If I must go into detail for you jokers, I guess I have to spell EVERYTHING out. Joke Joke HEHE
what have you experience with the tire at your given pressures, track temp, tire temps, # of laps and etc.. .
Modified by 6spdKEG at 2:56 PM 3/7/2007
Old Mar 7, 2007 | 10:47 AM
Ponyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6spdKEG &raquo;</TD></TR><TR><TD CLASS="quote">If I must go into detail for you jokers, I guess I have to spell EVERYTHING out.</TD></TR></TABLE>
Whoa...having a bad day? Seriously, you need to step back from the keyboard and take out your anger on your french poodle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6spdKEG &raquo;</TD></TR><TR><TD CLASS="quote">what have you experience with the tire at your given pressures, track temp, tire temps, # of laps and etc.. . </TD></TR></TABLE>
I only remember the ambient temp, pressures, and range of laps: 86, 33lb front and 29lb rear cold, llaps 12-16 if I kept at the same pace. The sheer amount of data points may be tough to gather. Good luck.
Old Mar 7, 2007 | 11:54 AM
6spdKEG's Avatar
You don't know me so that is probably why you took that offensively, but when I said Jokers.. . I was trying to display that I knew you were messing around with me. It's all good man. Sometimes the best of us can't come accross EXACTLY how we want to when we type.. .
gramkrackers
24
Aug 2, 2012 12:39 AM
beanbag
Jul 25, 2007 05:18 AM
VT VTEC
Aug 6, 2003 02:27 PM
ZCHF
Apr 10, 2003 08:23 AM
FullMetalJacket
12
Feb 28, 2003 07:32 PM
