Where is the Brake Master Cylinder Bleeder on a 1994 ex?
Old Mar 3, 2007 | 12:10 PM
Greg123's Avatar
Default Where is the Brake Master Cylinder Bleeder on a 1994 ex?
I'm trying to figure out how to bleed a newly installed brake master cylinder on a 94 Accord EX with ABS. Anyone know where the bleed valve is?? Thanks
Old Mar 3, 2007 | 12:22 PM
standbackimapro's Avatar
just bleed the entire brake system, theres bleeder screws on each caliper
Old Mar 3, 2007 | 12:51 PM
momstaxi's Avatar
Default Re: Where is the Brake Master Cylinder Bleeder on a 1994 ex? (Greg123)
if you were going to bleed the mc, wouldnt you need to bench bleed it by running lines back into the reseviour or with caps fittings for the outlets?
Old Mar 3, 2007 | 01:05 PM
Perfectionist's Avatar
Bench bleeding before installation is the prefered method. (Why pump all that air through the system?) A search should pull up the information on how to do this. But, in your case, I assume it's already installed.
All you can do now is bleed the system at the wheels. Lots of time and fluid involved. There is no "bleeder" for the brake MC.
Old Mar 3, 2007 | 01:55 PM
Greg123's Avatar
Default Re: Where is the Brake Master Cylinder Bleeder on a 1994 ex? (Perfectionist)
Perfect... thanks guys... I got her done
Old Mar 3, 2007 | 05:11 PM
JDM_DC4_Fanatic's Avatar
althought it is good that the matter is resolved. There is a way to bleed the MC. Pump the pedal and hold as you normally would, and crack the lines goin to the master. If theres air in the master, it will come out.
prelude5blue
Suspension & Brakes
Jul 2, 2014 08:43 AM
Crazed-Sol
Suspension & Brakes
Sep 1, 2009 05:39 PM
92integraVTECgsr
Nov 4, 2005 05:28 PM
Tenners
Sep 9, 2005 06:45 PM
magbarn
May 22, 2003 03:28 PM
