no vtec!!!
Ok....The TPS code is code 7 and it has nothing to Vtec. Now what I think you're doing is reading your cell wrong.
I bet you have a 1 long flash and 7 short flashes. That is a code 17 for the VSS. If the VSS isnt working......No Vtec. Other symptoms of bad VSS is no speedo, and rev limit at 7200 RPM's.
If you are having a VSS issue....I can help you fix it.
