98 Accord Timing Belt work - how to remove front crank pulley
Old Mar 3, 2007 | 10:11 AM
dkasakitis's Avatar
Default 98 Accord Timing Belt work - how to remove front crank pulley
Folks, I'm in the middle of a timing belt (and water pump change). I've done plenty of B motors, but this is my first V6 (98 Accord V6 EX 4 door). I've removed both accessory belts and relocated the power steering pump out of the way. I've removed the side motor mount and have a jack under the tranny/motor. I've also removed the upper timing belt covers. I'm down to removing the front pulley / harmonic balancer and that's where I'm stuck.
I have a pretty good Ingerol Rand impact gun but can't get the 19mm bolt to budge. I'm assuming it's threaded normally, so counter-clockwise should take it off. The pulley doesn't have the internal mega hex like B motors so it doesn't appear you need to use the crank holding tool.
Any advice on how to remove the front crank pulley/harmonic balancer is much appreciated. Nope, I don't have the Helms manual... I'm searching for that now but generally the stores around there just carry the Chilton's stuff.
Thanks much, Dave K.
Old Mar 4, 2007 | 03:16 PM
hondadude's Avatar
Default Re: 98 Accord Timing Belt work - how to remove front crank pulley (dkasakitis)
you might try to hydrolock your impact for more power.
If an engine turns clockwise you can brace a breaker bar against the ground and bump the starter.
joiv21
11
May 16, 2013 06:50 AM
JDM_SOHC
27
Sep 28, 2009 09:05 AM
EG6 Love
Mar 18, 2008 05:33 PM
Powered by VTEC
Jan 29, 2008 05:58 PM
h46it
Mar 21, 2002 07:57 AM
