question
hey guys i have two questions um 1 wondering what oil i should use for my h22 civic i was just thinking like castrol 5w 30 or something what do u think? number 2 left my car sitting around for over a month should i change the oil before i start it or start it up let it warm up then change it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_guy »</TD></TR><TR><TD CLASS="quote">hey guys i have two questions um 1 wondering what oil i should use for my h22 civic i was just thinking like castrol 5w 30 or something what do u think? number 2 left my car sitting around for over a month should i change the oil before i start it or start it up let it warm up then change it?</TD></TR></TABLE>
Any quality 5W-30 motor oil will be fine.
If the only reason you're changing the oil is because the car has been sitting for a month, I wouldn't bother doing it. However if it needs an oil change anyway, just let it run a bit until it's warm, then shut it off and change the oil.
I'd recommend just starting the car, letting it warm up, and check it. If it's dirty I'd change it, but just sitting for a month wouldnt make you need to do a change inless it needs it.
and yeah any 5w-30 will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer21 »</TD></TR><TR><TD CLASS="quote">you should always change th oil with the engine hot</TD></TR></TABLE>
Actually I'm pretty sure it doesn't matter worth of ****.
Only reason for heating it up is so it flows either. At lest I'm pretty sure that's what it's all about. Don't know, I always make sure it's hot when I change it
