is there a difference in OBD1 and OBD2 alternators for B-series...
Old Mar 3, 2007 | 04:28 AM
BoostinEJ1's Avatar
Default is there a difference in OBD1 and OBD2 alternators for B-series...
I looked on slhondaparts and the part number is different but when I went to the auto parts store I had them look up a 99 Si alt. and a 94 Del Sol VTEC and both were the same exact thing. The only difference there could even be in the connection to the wire harness. None the less if someone could let me know because if they are the same I have one otherwise I have to go buy one ASAP. Thanks
Old Mar 3, 2007 | 05:05 AM
ITS_Dunn's Avatar
one is a 4 wire the other is three. If you want to use it for some reason, you can just wire it up to the three, one of them you dont need. I cant remember, but its on here.
Old Mar 3, 2007 | 05:54 AM
BoostinEJ1's Avatar
Default Re: (Dunn@ITS)
i searched on here and say you can switch out the plug piece on the alt. if needed. ended up fixing the problem though so thanks anyway
Old Mar 3, 2007 | 06:08 AM
egmatt93's Avatar
Default Re: (SHG_EM1-R)
would this cause a cel if u have a obd2 motor in a obd1 car, because i have a cel for a top dead center sensor and im not sure if i have to get a obd1 dizzy... any opinions? (sorry to thread jack)
Honda newwbie
May 27, 2018 02:40 PM
honda_ek9
Apr 30, 2008 04:59 PM
Cyphear
Jul 13, 2007 03:58 PM
bigtimlikewhoa
Nov 12, 2005 06:57 PM
Hockey27925
Aug 22, 2005 08:17 PM
