car loosing anti freeze
Old Mar 2, 2007 | 11:45 PM
john457's Avatar
Default car loosing anti freeze
my car keeps loosing anti freeze and i dont know where its leaking any ideas on how to find the leak. ps there is know puddle under the car
Old Mar 3, 2007 | 12:09 AM
JDM_Frijoles's Avatar
Default Re: car loosing anti freeze (john457)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john457 &raquo;</TD></TR><TR><TD CLASS="quote">my car keeps loosing anti freeze and i dont know where its leaking any ideas on how to find the leak. ps there is know puddle under the car</TD></TR></TABLE> Try actually following the coolant hoses and looking for cracks, currosion, dry rot, or fukked up clamps. Its easy **** dude, theres like 3 hoses I think tthat you gotta check. try also your radiator.
Old Mar 3, 2007 | 05:37 AM
excivicboy96's Avatar
Default Re: car loosing anti freeze (JDM_Frijoles)
does it leak when the engines cold, warm or both?
Old Mar 3, 2007 | 06:21 AM
jdmnorice's Avatar
Default Re: car loosing anti freeze (excivicboy96)
it is probly a slow leak and burning befor it hits the ground you would have to do a preasure test to locate the leak
Old Mar 3, 2007 | 06:26 AM
pdiggitydogg's Avatar
You need to find the source...end of story
No one is going to be able to say "its here" just by you saying "I have a leak" and "Theres a puddle"
Look at where the center of the puddle is, see where its dripping. Follow the stream to the source.... Duh
Look at your coolant hoses from the radiator, at the head, behind the head @ block, near the water pump (under timing cover).
You need to investigate...
Old Mar 3, 2007 | 06:34 AM
posite's Avatar
Sometimes it is a hose that is dry rotted so while you are looking actually move the hoses just a little and you may see it go spraying. Keep an eye on the weep-hole on the back of the engine. If it seems to be coming from that then look forward to replacing that water pump.
omgwtfbbq
Jun 7, 2009 07:27 PM
john457
Mar 3, 2007 05:45 AM
lspecz
Feb 28, 2007 01:45 PM
Rhythmsnewsn
Jun 17, 2006 01:15 AM
boosted civic 2k6
Sep 17, 2005 04:31 PM
