coolant leak
coolant leak
I can't seem to find my coolant leak on my b18c1, there is coolant on the axles,shifter linkage, some sensors, and a bar that leads to one of the lca, anybody got an idea?
* B A N N E D *
Re: coolant leak (lspecz)
instead of playing the guessing game get some compatible UV dye and add it to the system....drive the car a bit, let it sit, and then trace the leak accordingly
Re: coolant leak (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">instead of playing the guessing game get some compatible UV dye and add it to the system....drive the car a bit, let it sit, and then trace the leak accordingly</TD></TR></TABLE>
yah damnnn right
yah damnnn right
Re: coolant leak (Hungry4Boost)
Did u ever remove the radiator hose from behind the intake manifold. if you did then most likely the radiator hose clamp is not on all the way. I changed my motor mount and never bothered to put it on all the way since it was a pain in the ***. or maybe it just ruptured from old age.
