Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how hard is it to install HFP lip kit?
Old Mar 2, 2007 | 10:37 PM
norcal450's Avatar
Default how hard is it to install HFP lip kit?
well unless i get an incredible deal from the dealer i will be ordering the HFP lip kit elsewhere and installing it myself.
who's done it? any tips or recommendations? unless its super easy i wouldnt mind paying 100-200 to have dealer or someone install it. just to give you an idea of $ vs. a headache or time for me
i installed the OEM body kit on my 01 gs-r and hopefully the SI is the same
Old Mar 2, 2007 | 10:50 PM
faster Type R's Avatar
bump....someone make a DIY
Old Mar 3, 2007 | 01:02 AM
IGotNoSwap's Avatar
Default Re: how hard is it to install HFP lip kit? (norcal450)
diy thread would be nice
Old Mar 3, 2007 | 03:26 AM
Type X's Avatar
the instructions provided from honda for the install are pretty extensive
its not that hard of an install but like everything...has some things to watch out for
Old Mar 3, 2007 | 05:18 AM
FBPSidan's Avatar
Default Re: how hard is it to install HFP lip kit? (Type X)
ive done several for the coupe and the sedan, i think the sedan is a tad easier. it tells you to cut the rear bumper but dont! if you ever take the kit off you now have to get a new bumper. it will fit over it...trust me! as for the side brackets, do not put them on the car first like it tells you to, slide em into the sideskirts and peel off tape backing and put them on car from there.... WAAAAAAAAAAAAYYYYYYY easier!!! When you do it, make sure its warm out and you clean the surface your will be sticking kit to VERY WELL or it will not hold all the way around. Thats all i can think of, if you got any questions, lemme know.
Old Mar 3, 2007 | 05:51 AM
Demonis's Avatar
Default Re: how hard is it to install HFP lip kit? (FBPSidan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBPSidan &raquo;</TD></TR><TR><TD CLASS="quote">ive done several for the coupe and the sedan, i think the sedan is a tad easier. it tells you to cut the rear bumper but dont! if you ever take the kit off you now have to get a new bumper. it will fit over it...trust me! as for the side brackets, do not put them on the car first like it tells you to, slide em into the sideskirts and peel off tape backing and put them on car from there.... WAAAAAAAAAAAAYYYYYYY easier!!! When you do it, make sure its warm out and you clean the surface your will be sticking kit to VERY WELL or it will not hold all the way around. Thats all i can think of, if you got any questions, lemme know.</TD></TR></TABLE>
From your experience, it sounds like it is your duty to write up a DIY thread on this! hehe, good input!
I read it's easier with two people... maybe take that into consideration.
Old Mar 3, 2007 | 07:44 AM
IT GUY's Avatar
Default Re: how hard is it to install HFP lip kit? (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">
I read it's easier with two people... maybe take that into consideration.</TD></TR></TABLE>
I vote with Demonis.. FBSidan hooks us up with a DIY FTW
Old Mar 3, 2007 | 02:19 PM
jennifermike's Avatar
Default Re: how hard is it to install HFP lip kit? (IT GUY)
peice of cake, get the DIY from the dealer(instructions), i did ours in like an hour and a half, do what he said about the sides, dont follow the instructions
Old Mar 3, 2007 | 02:41 PM
TRE_'s Avatar
Default Re: how hard is it to install HFP lip kit? (jennifermike)
The front and rear lips are pretty straight forward. As mentioned make sure that the surfaces where adhesive will be applied are clean(use rubbing alch.) and doing it in warm weather is a must... or use a hairdryer if its cold out.
the sideskirts take a little more work as far as lining up the brackets and everything(easiest with two people), but none of it is really that difficult.
The best DIY write-up is the honda instructions IMO
Old Mar 3, 2007 | 03:43 PM
hawaiian06si's Avatar
Default Re: how hard is it to install HFP lip kit? (TRE_)
around what temp out side should it be to put it on.
Old Mar 3, 2007 | 07:03 PM
Default Re: how hard is it to install HFP lip kit? (hawaiian06si)
i think it says 60 or more
Old Mar 4, 2007 | 04:33 AM
japspecjohn's Avatar
get some better sticky tape from 3m cuz OEM sucksssss
Used019
Jan 8, 2008 07:15 PM
blue rocket
Apr 12, 2007 02:43 PM
blue rocket
31
Mar 28, 2007 07:04 PM
baybeboi
Jul 9, 2003 12:45 AM
sk4sk4
May 18, 2002 07:42 PM
