GT2871R .63 ar b16 slower than average spool up?
Old Mar 2, 2007 | 09:50 PM
batboyvaj's Avatar
Default GT2871R .63 ar b16 slower than average spool up?
stock b16, ctr cams, victorx, 3" turbo back, 750cc inj, profec b spec 2. I'm getting 10 psi around 4.5-4.6k rpms. I thought this turbo would spool a little faster. I have my manifold coated also. What else can I do to help out spooling this thing?
My settings on my profec are (8.7 psi spring)
set boost 3%
Gain 6%
start boost 8 psi
Old Mar 3, 2007 | 02:00 PM
spoolin turbo s's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (batboyvaj)
you can't ask for much more than 3500 rpm's of powerband without revving to 9k
looks good to me especially at only 10 psi
only thing i could think of is if you absolutely want it to spool faster you could try a .48 hotside but i wouldn't
Old Mar 3, 2007 | 02:06 PM
93supercoupe's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (spoolin turbo s)
Turn the boost up, then maybe it would hit 10lbs sooner.
Old Mar 3, 2007 | 05:42 PM
LilCivic04's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (93supercoupe)
Just look at the curve of the graph, just like N/A. what more can you ask?
Old Mar 3, 2007 | 07:43 PM
batboyvaj's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (LilCivic04)
i'm just looking at different setups and some people get the same spool with larger turbos. I guess I was just expecting to much from this turbo. It does feel like a BIG na motor though.
Old Mar 3, 2007 | 08:01 PM
HiProfile's Avatar
Best solution would be to build an LS shortblock and toss that in.
Honestly if you plan on keeping 300-325whp, you might want to look into a GT28RS or similar. That compressor is good for close to 400 (rated at 420 by garrett), so its not even close to its peak. 2.5bar sensor + GT28RS@18psi FTW.
Old Mar 3, 2007 | 08:22 PM
Drew Peacock's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (HiProfile)
Yup you a have little B16 I would be happy with that. Give it 15 psi and you will be smiling.
Old Mar 4, 2007 | 08:45 AM
LeGeND4LiFe's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (turbozxi)
.48ar T3 turbine housing is equivalent to the .64ar T25 housing it originally was designed with from Garrett, and would definitely drop several hundred rpm off the spool time.
You could also turn up the boost and maybe increase the gain on the boost controller; nice graph though. Any pics/vids?
Old Mar 4, 2007 | 09:31 AM
RacerXI's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (LeGeND4LiFe)
I'd try turning up the gain also. Some have reported the victorx hurts spool b/c of it's large plenum also.
Old Mar 4, 2007 | 01:40 PM
batboyvaj's Avatar
Default Re: GT2871R .63 ar b16 slower than average spool up? (RacerXI)
maybe my boost controller isn't even doing anything because the set boost % is so low. I was looking at my dyno again and it starts at 8.5 psi but creeps up to 10.5
Old Mar 4, 2007 | 11:50 PM
Yeah, I noticed the same thing. You could turn up the gain to the point where it ramps up fast enough to "overshoot" your target boost level by a bit, ie spools fast and passes 10psi hitting 11-12psi for a moment, then settles back down at your target of 10psi.
Old Mar 5, 2007 | 01:20 AM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj &raquo;</TD></TR><TR><TD CLASS="quote"> I thought this turbo would spool a little faster. I have my manifold coated also. </TD></TR></TABLE>
First misconception about ball bearing turbos is thinking that they would spool signifcantly earlier. Nope, a size reduction in turbine housing can probably change the spool time more.
Second misconception is thinking GT series ball bearing turbos spool way faster than the non BB turbos. It spools faster, but that's not what you buy a GT-series for. The GT-series turbos are really well known for their amazing response at a wide range of RPM and boost levels. The reason why your car feels like a big NA motor is from the increased turbine flow across a wide range of turbine speeds (yet lag hasn't increased). A regular non-BB and non-GT turbo would lag like hell with similiar turbine flow and compressor size.
If you want early spool, you might as well get a T3/T4 57-trim, and shrink the hell out of the turbine housing so you get mad spool from 3000-4000RPM. But it's going feel like a load of crap anywhere you hit the throttle between shifts, or even booting around town with lots of fluctuations with throttle position. It sure won't feel like anything close to a bigger NA motor, that's for sure
Lastly, what's your exhaust setup? Stock cat, 2.5" exhaust, etc? Or 3" straight, no cats, etc? The exhaust setup alone can change spool time +/- 1000RPM in most cases.
Old Mar 5, 2007 | 02:18 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeGeND4LiFe &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I noticed the same thing. You could turn up the gain to the point where it ramps up fast enough to "overshoot" your target boost level by a bit, ie spools fast and passes 10psi hitting 11-12psi for a moment, then settles back down at your target of 10psi. </TD></TR></TABLE>
Try not to "overshoot". That spiking could have some catastrophic results if the exhaust stream isn't properly channeled, or the car is not tuned well. you can change the start gain to work with the gain of the boost controller to keep it from "overshooting". Find that balance to have the response of the turbocharger work FOR you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
Couldn't have been said better.
Old Mar 5, 2007 | 04:40 PM
batboyvaj's Avatar
i got a 3" all the way back no cats
Old Apr 27, 2007 | 10:07 AM
red_crx's Avatar
Default Re: (batboyvaj)
I noticed that my turbo would spool up faster after I wrapped my manifold and downpipe with the thermal wrap.
Old May 2, 2007 | 04:54 PM
batboyvaj's Avatar
i guess it would help if my boost selenoid was actually pluged in eh? HA....those damn little wires came out of the harness so my selenoid was just there with no control from the main unit.
once i hooked it up, my boost goes straight to 10psi without stopping at 8.5 first then creeping up.
Old May 2, 2007 | 08:35 PM
lol glad to hear you found the culprit....what rpm are you hitting full boost at now?
Old May 3, 2007 | 12:57 AM
abnaasefmb's Avatar
Default Re: (LeGeND4LiFe)
heat spools the turbo as well, it looks like you could pull some fuel out in the lower rpms
Old May 3, 2007 | 09:10 AM
batboyvaj's Avatar
i get all 10 lbs around 4,400 now. before it would just creep up to 10 psi. I will try to take fuel out of the lower range. Thanks for the tip
Old May 3, 2007 | 09:38 AM
1158's Avatar
Do you have cam gears? After I put in my CTR cams and had the gears adjusted the car spooled about 500 rpm earlier. I guess it could be just the change in cams that did it, I went from GSRs to CTRs, but I have a feeling it was the cam gear adjustment. This was on a B18C1, so your results may vary...
b16ajdmrex
May 23, 2009 09:20 AM
honda_mike
Oct 29, 2008 10:46 AM
GetawayInMoscow
Mar 4, 2007 11:56 AM
92redhatch
Oct 17, 2006 05:49 AM
