3rd, 4th, 5th gear spin out
Old Mar 2, 2007 | 07:00 PM
jorge59la's Avatar
Default 3rd, 4th, 5th gear spin out
if im spinning out on all this gears will an LSD fix that problem?
Old Mar 2, 2007 | 07:02 PM
kiddcarbuff's Avatar
so ur spinning tire in 3rd 4th and 5th? but not first and second? seems FUCKED UP. lsd will help some. how much pwoer are you making, what are you running for tires
Old Mar 2, 2007 | 07:04 PM
jorge59la's Avatar
Default Re: (kiddcarbuff)
well of course if im spinning in 3-4-5 then obviously 1-2 also.
im pulling around 295whp on 9-10 psi
Old Mar 2, 2007 | 07:05 PM
jorge59la's Avatar
Default Re: (jorge59la)
Toyo Proxes FZ4
Old Mar 2, 2007 | 07:10 PM
PrinceAli132's Avatar
Default Re: 3rd, 4th, 5th gear spin out (jorge59la)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorge59la &raquo;</TD></TR><TR><TD CLASS="quote">Toyo Proxes FZ4</TD></TR></TABLE>
No wonder your spinning, those are garbage tires for performance.
Ali
Old Mar 2, 2007 | 07:12 PM
jorge59la's Avatar
Default Re: 3rd, 4th, 5th gear spin out (PrinceAli132)
what do u recommend
Old Mar 2, 2007 | 07:15 PM
How much are you willing to spend?
Do you care about treadlife?
Is the car driven in the bad weather?
Ali
Old Mar 2, 2007 | 07:20 PM
jorge59la's Avatar
weather is great here in CA from 70-90 deg. right now
treadlife should be reasonable.
i want something good for the money.
Old Mar 2, 2007 | 07:28 PM
BFG Goodrich Drag Radial - approx 7k miles +/- a bit depending upon the beating
225/50/15 or 225/50/15 approx 125 from tirerack
Falken Azenies - approx 10k +/- a bit depending upon the beating
205/50/15 approx 75 from edgeracing
What do you consider reasonable treadlife? Its going to be hard to get decent treadlife, with reasonable pricing that will also help give you traction.
Ali
Old Mar 2, 2007 | 11:11 PM
dvp's Avatar
dvp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">No wonder your spinning, those are garbage tires for performance.
Ali</TD></TR></TABLE>
Worse tire I ever had.
Azenis
Kumho MX as well.
Old Mar 3, 2007 | 04:38 AM
j_bizach's Avatar
Default Re: 3rd, 4th, 5th gear spin out (dvp)
Azenis suck Fusions to
Old Mar 3, 2007 | 08:59 AM
jorge59la's Avatar
Default Re: 3rd, 4th, 5th gear spin out (j_bizach)
should i just go with the yokohama advan?
streetlights
Nov 28, 2007 08:03 AM
YipMan_Style
12
May 18, 2007 09:04 PM
Bense
Oct 18, 2006 08:06 PM
Apex i ITR
Jan 28, 2005 10:12 AM
b18cTurbo
Feb 26, 2002 02:17 PM
