Bleed brakes to replace RTA bushings?
Well I am in the process of taking the rear trailing arm off to replace the infamous RTA bushing. 2 problems: the brake line seems to need to be disconnected; the e-brake cable seems to need to be disconnected. Is this needed?
Yes, you will need to disconnect the brake lines and cable. Also when you put them off just take the bolts off the TA, especially the compensator arm bolt otherwise it will mess your alignment up.
