idle problem or fuel pump problem? B20B CRV motor, stall coming to stop or nuetral
Old Mar 2, 2007 | 03:07 PM
MKEK9's Avatar
Default idle problem or fuel pump problem? B20B CRV motor, stall coming to stop or nuetral
need help, thanks in advance!
recently swapped B20B motor in civic, it suffers from surging idle slightly a little bit during start-up, and large fluctuations after car is warmed-up, and car stalls on nuetral coming to a stop.
changed IACV, cleaned out FITV, but symptoms still exists.
I am still using stock civic fuel pump, is this a idle problem or a fuel pump problem? how can I fix this problem, suggestions?
(also, throttle feels weak now when the car is moving)
thanks!!!
Old Mar 2, 2007 | 04:20 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: idle problem or fuel pump problem? B20B CRV motor, stall coming to stop or nuetral (MKEK9)
checked for VAC leaks?...i don't think your FP has anything to do with it
Old Mar 5, 2007 | 08:42 PM
MKEK9's Avatar
Default Re: idle problem or fuel pump problem? B20B CRV motor, stall coming to stop or nuetral (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">checked for VAC leaks?...i don't think your FP has anything to do with it</TD></TR></TABLE>
thanks, i changed out the IACV and cleaned the FITV, and check for vacuum leaks, but the symptoms didnt go away, any idea what the problem might be?
Old Mar 5, 2007 | 08:44 PM
95DxSi-R2
Guest
Posts: n/a
try adjusting your idle
Old Mar 5, 2007 | 08:46 PM
93eg2james's Avatar
Not the fuel pump. I've been running my stock Del Sol SI pump (1.6 SOHC VTEC) with no problems at all, however I did change to a Walbro 255. I'm willing to bet that your fast idle went bad. Very common problem in Hondas. I would further look into that.
Old Mar 5, 2007 | 08:50 PM
MKEK9's Avatar
Default Re: idle problem or fuel pump problem? B20B CRV motor, stall coming to stop or nuetral (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">try adjusting your idle</TD></TR></TABLE>
yeah, i did, but it didnt help
the car would start off idling pretty high, and as the car starts to warm it, the rpm fluctuations starts to get lower and lower, until the car finally dies (stalls), and when i start the car again, it would die again
thanks!
Old Mar 5, 2007 | 08:52 PM
MKEK9's Avatar
Default Re: idle problem or fuel pump problem? B20B CRV motor, stall coming to stop or nuetral (93eg2james)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james &raquo;</TD></TR><TR><TD CLASS="quote">Not the fuel pump. I've been running my stock Del Sol SI pump (1.6 SOHC VTEC) with no problems at all, however I did change to a Walbro 255. I'm willing to bet that your fast idle went bad. Very common problem in Hondas. I would further look into that. </TD></TR></TABLE>
i cleaned out my FITV and tightened the screw, following the instructions i found on HT, but i am not sure, any ideas how i can test that my current FITV is bad?
thanks!
Old Mar 5, 2007 | 08:58 PM
93eg2james's Avatar
Yeah, you can test it. I'm not sure if you noticed, but when you take the entire thing apart, there is a little thermostat inside of there. Unscrew that huge white plastic screw and take out that assembly that resembles a thermostat. Put that in some boiling water and see if it reacts. If it does nothing, its bad.
Old Mar 5, 2007 | 09:03 PM
MKEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, you can test it. I'm not sure if you noticed, but when you take the entire thing apart, there is a little thermostat inside of there. Unscrew that huge white plastic screw and take out that assembly that resembles a thermostat. Put that in some boiling water and see if it reacts. If it does nothing, its bad.</TD></TR></TABLE>
forget to ask, i was thinking since only older hondas have the FITV, howcome the B20's come equiped with the FITV? i think mine motor is from a 97 B20
should i just try to block off the FITV, and get rid of it all together?
thanks!
Old Mar 6, 2007 | 01:36 AM
98civicEKex's Avatar
I had the same problem with my built B!^ after i changed to a skunk 2 68mm throttle body and skunk 2 intake manifold on a p73 ecu (Integra type R OBD2) I found that after trying to adjust the idle screw on the throttle body didnt work, cleaning the FICV didnt help, the tps, map, and iat sensors all worked. The problem I was having was there was no PCV hooked to the intake manifold(hooking it up helped) also if you run an ITR or skunk 2 manifold you eliminate the dual butterfly valve inside the manifold to a single valve which increases airflow, so if you are running your stock ecu you might want to upgrade to an OBD1 and fun a air/fuel management system on it. good luck.
Old Mar 6, 2007 | 12:27 PM
Blk00EJ8's Avatar
Default Re: idle problem or fuel pump problem? B20B CRV motor, stall coming to stop or nuetral (98civicEKex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civicEKex &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem with my built B!^ after i changed to a skunk 2 68mm throttle body and skunk 2 intake manifold on a p73 ecu (Integra type R OBD2) I found that after trying to adjust the idle screw on the throttle body didnt work, cleaning the FICV didnt help, the tps, map, and iat sensors all worked. The problem I was having was there was no PCV hooked to the intake manifold(hooking it up helped) also if you run an ITR or skunk 2 manifold you eliminate the dual butterfly valve inside the manifold to a single valve which increases airflow, so if you are running your stock ecu you might want to upgrade to an OBD1 and fun a air/fuel management system on it. good luck.</TD></TR></TABLE>
Not trying to be a dick but this is the 2nd post with bad info. PLEASE stop advising people to switch to OBD1 and some sort of management to fix idle problems!
Old Mar 6, 2007 | 04:55 PM
MKEK9's Avatar
any chance it might be the fuel filter clogged up?
restrictive fuel filter?
thanks!
HGL1668
Sep 19, 2006 06:08 PM
Mister Jew
Apr 12, 2006 05:53 PM
GRPNHRD
16
Nov 29, 2005 09:44 PM
94AcuraIntegraGsr
Nov 15, 2005 04:57 PM
Green94GSR
Aug 18, 2003 11:35 AM
