High Idle
Old Mar 2, 2007 | 10:57 AM
DeCoY's Avatar
Default High Idle
Ok I'm a noob but i couldnt find any posts with simple steps to try and fix this problem.
B18C Motor idles at 2500 when cold. Once fully warm idles at 1100 and fluctuates up and down from 1100 to 1300. used to idle lower like around 800.
Any steps i should take to try and remedy this would be much appreciated.
Old Mar 2, 2007 | 03:25 PM
j_bizach's Avatar
Default Re: High Idle (DeCoY)
Its a vacume problem seach that theres hundreds of post on that. Too lazy to explain
Old Mar 2, 2007 | 04:49 PM
quadnie's Avatar
Vacuum leak, throttle body butterfly not shut/warped, FITV, IACV
Check all that
Old Mar 2, 2007 | 06:27 PM
schardbody's Avatar
yep, grab a can of carb cleaner or starting fluid and start spraying around the intake manifold, throttle body area, and also the vacuum hoses on the firewall. when the engine revs higher wherever you just sprayed has the leak.
Old Mar 3, 2007 | 11:39 AM
DeCoY's Avatar
Ok so i sprayed carb cleaner all around my throttle body and intake manifold, no changes. I also noticed today that when my foot is on the brake the Idle fluctuates between 1000-1200 but when i take my foot off it stays at about 1000.
If anyone has any other advice that would be awsome, thnx.
Old Mar 4, 2007 | 05:14 AM
j_bizach's Avatar
Default Re: (DeCoY)
IACV clean that. MAP clean that. Double check ALL of your vacume lines. Make sure your butterfly isnt cracked open from build up
Old Mar 10, 2007 | 09:22 AM
cpriest_347's Avatar
Vaccum problem? Most likely...but from where. If it has a Fast Idle Thermo Valve on the throttle body, that could be the problem. It raises the idle when its cold and once the engine is warm the idle should drop down to normal. Take your intake tube off and put your finger over the little hole inside the TB. If it is sucking air, then thats your problem. Haynes Manuels are a big help as well. "Write that down"
Old Apr 3, 2007 | 03:07 PM
Yak BallZ's Avatar
Default Re: High Idle (cpriest_347)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpriest_347 &raquo;</TD></TR><TR><TD CLASS="quote">Vaccum problem? Most likely...but from where. If it has a Fast Idle Thermo Valve on the throttle body, that could be the problem. It raises the idle when its cold and once the engine is warm the idle should drop down to normal. Take your intake tube off and put your finger over the little hole inside the TB. If it is sucking air, then thats your problem. Haynes Manuels are a big help as well. "Write that down" </TD></TR></TABLE>
How do you fix this Problem? Please explain.
BTW Sorry to bring this back from the dead, but I have this problem too.
Cuda70
Jul 27, 2010 04:44 AM
Gho$t
Nov 10, 2009 10:26 PM
TegraD
May 15, 2009 02:55 PM
twentyhurtz
Dec 5, 2008 07:30 PM
b16a3delsol
Aug 15, 2007 09:29 AM
