throttle cable question (searched)
Old Mar 2, 2007 | 10:14 AM
B18CUL8R's Avatar
Default throttle cable question (searched)
i did a jdm b16 swap into my 94 civic dx coupe
first off im gonna keep the factory throttle cable....bottom line
second my bracket wont allow that unless i modify it
my swap didnt come with the throttle cable bracket on the IM....
now i have managed to find a throttle cable bracket(i think off a gsr or b16 not sure) but apparently when i install it i cant get my part on the cable that sits in the bracket to actually sit in the bracket.....the space on the cable sits roughly 1.25 inches away from the holder on the bracket.
here is a pic i found of the bracket im talking about but instead of the bracket facing the t-belt side it faces the dizzy side (which one do i have? i think it says p2t on it meaning "b16" am i correct?)
but anyway the bracket doesnt fit onto the cable. like i said the bracket sits about 1.25 inches to the right of the spot on the cable that it needs to lock onto. see my ghetto picture below lol
i was gonna try use plumbers tape tripled up to make me a half *** piece so i can move the cable bracket over 1.25 inches
now before i hack me a gangster *** throttle cable bracket is there an oem throttle cable bracket that i can use so i can retain my factory dx throttle cable?
id hate to have to spend money on a new cable when a bracket or making an extension is way simpler
thanks h-t
Modified by B18CUL8R at 7:37 PM 3/2/2007
Old Mar 2, 2007 | 11:55 AM
jlfrnce's Avatar
Default Re: throttle cable question (B18CUL8R)
i have the same problem but on mine the cable itself is way too long is the and adjustment under the dash or something? i have a 94 ls and swapped in a b18c1
Old Mar 2, 2007 | 08:36 PM
93FlatBlackHatch's Avatar
When I did a b16 swap in my eg civic I had to buy a type r throttle cable. Put it on and it fit perfect.
Old Mar 3, 2007 | 08:18 AM
sauceja's Avatar
Default Re: (93FlatBlackHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FlatBlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">When I did a b16 swap in my eg civic I had to buy a type r throttle cable. Put it on and it fit perfect.</TD></TR></TABLE>
Yep type r throttle cable and got the bling P73 cable bracket as well. It was only like 35.00 from a company but I can't remember who.
Old Mar 3, 2007 | 07:08 PM
gs1gsr's Avatar
Default Re: (sauceja)
password jdm makes a throtal bracket for that problem check it out
mouab18c1
20
Jul 9, 2013 11:36 PM
Crank
Nov 7, 2008 02:30 PM
97_coupe
Sep 2, 2008 08:56 AM
STG3PWR
Feb 19, 2005 08:27 PM
