Idle Air Control Valve
Old Mar 2, 2007 | 07:49 AM
BG-Teg's Avatar
Default Idle Air Control Valve
if you dont hook up the IACV would you gain any power,i ask becasue doesnt it heat up the IM?, i know its not a serious lose in power but i was just asking...
Old Mar 2, 2007 | 07:54 AM
SuzukaBlueAP2's Avatar
Default Re: Idle Air Control Valve (95tealteg)
No. Your car will not run properly without it there and functioning.
It's purpose is to allow air to bypass the throttle plate in order to help regulate the engine idle speed.
Old Mar 2, 2007 | 07:55 AM
Preferio's Avatar
Default Re: Idle Air Control Valve (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">No. Your car will not run properly without it there and functioning.
It's purpose is to allow air to bypass the throttle plate in order to help regulate the engine idle speed.</TD></TR></TABLE>
You'll lose power...
Old Mar 2, 2007 | 08:05 AM
BG-Teg's Avatar
Default Re: Idle Air Control Valve (PreFerio)
ok becasue i know a guy that doesnt run his in any of his cars(gsr hatch) it sounded cammed then i figured out he didnt hook up the IACV, he said it gained power....ok thanks its all clear now
fenix4o9
Feb 25, 2010 11:03 PM
CRXCIVICMIX
Jul 7, 2006 12:04 PM
fe519
Nov 8, 2004 06:08 AM
jaycapz
Sep 24, 2004 08:12 PM
ZeroGSR
Sep 10, 2003 03:42 PM
