How to fix door rust?
Old Mar 2, 2007 | 06:47 AM
ludesrv's Avatar
Default How to fix door rust?
I'm attempting my own paint job. I've studied the body panels that need replacing and I'm confident I can do a good job. I have the metal body panels, the welder, all the tools the place and helpers so I'm set.
The only thing I can't figure out is how to fix the common canadian car door rust. The bottom of the door lip is rusted and showing on the outside (from the weld to the outside panel). I was just gonna grind it all down to bare metal, bondo it, and sand it smooth but I want to do it right so it won't crack up on me. Maybe a metal mesh should be used? I dunno. I don't wanna pull the panel off and everything. Maybe weld in a new peice where needed? If anyone works at a shop or knows what to do it would be greatly appreciated. I'll be doing the same thing to an Accord aswell so lemme know.
Old Mar 2, 2007 | 09:02 AM
janz3n's Avatar
Default Re: How to fix door rust? (ludesrv)
what you should do is cut the bottom half or less of the door skin off and weld a new piece in. that would be the right way to do it. if the rust isnt going all the way thru im sure you can just grind it down put some rust pant on there , use some filler and sand it smooth. but not if theres any holes.. unless you dont care how long the paint job lasts.
Old Mar 2, 2007 | 09:15 AM
wiZCo's Avatar
Stouts 'n' Scotch
use POR-15 on any spots you don't want to weld and that aren't pitted. I've used it with great success on my car, note I live in WI too.
Old Mar 2, 2007 | 09:59 AM
janz3n's Avatar
Default Re: (wiZCo)
ya por15 is great.. so iv been told. didnt use that name because i didnt know if you can get that stuff in the states..
EKSedAndy
Paint and Body
Mar 11, 2009 06:42 PM
K24_Y61P
Honda Civic (2001 - 2005)
33
May 18, 2007 09:12 PM
qazaq
Nov 18, 2006 10:21 AM
crxgator
Feb 28, 2004 08:39 PM
D21X
Apr 15, 2003 09:55 PM
