oil in spark plugs
Old May 21, 2002 | 07:00 PM
Doogie Howser's Avatar
Default oil in spark plugs
i was putting on a new valve cover and i wasnt thinking well i was doing it and forgot to put the spark plug gaskets/grommets in. The next day i rembered and i took out my plug wires and the chamber had about 1/2 inch in each one, i took out my plug and drained the oil in the combustion chamber, then i replaced the spark plugs and put the grommets in (im dumb). i was wondering off course it smoked after i started it up and drove for a while, but are there going to be any problem from the oil going down there or should it be fine now?
Old May 21, 2002 | 07:58 PM
FifthGearOnline's Avatar
Default Re: oil in spark plugs (mlambrecht)
your engine is screwed get a new one nahh it should be fine
Old May 21, 2002 | 08:29 PM
John's Avatar
New User
You'll be fine, but put those spark plug seals (grommets) back in as soon as you can...
Old May 22, 2002 | 11:59 AM
Default Re: oil in spark plugs (DunReit)
yea i put them in, thnaks for the help
fjt
Nov 23, 2004 08:52 AM
illusion
Apr 30, 2003 06:47 PM
professorman
Feb 19, 2003 07:27 AM
si91
May 28, 2002 07:33 AM
G2_Integ
Aug 26, 2001 03:35 PM
