wire question reguarding wire tuck
Old Mar 1, 2007 | 07:11 PM
rsdriver17's Avatar
Default wire question reguarding wire tuck
i did a wire tuck not to long ago and i used 14guage wire for everything. question is, do u think the bigger wire will effect the wire going to the ecu and such . like power and all ?
Old Mar 2, 2007 | 05:58 PM
rsdriver17's Avatar
Default Re: wire question reguarding wire tuck (rsdriver17)
need advice
Old Mar 2, 2007 | 07:14 PM
ekb16's Avatar
the bigger the wire the more resistance you will have...im not 100% sure but i think automotive uses 18-22 gauge wire for sensors n stuff
Old Mar 2, 2007 | 11:16 PM
dartdc97's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">the bigger the wire the more resistance you will have...im not 100% sure but i think automotive uses 18-22 gauge wire for sensors n stuff</TD></TR></TABLE>
the bigger the wire, the less resistance it gives.
rsdriver17's Avatar
Default Re: (ekb16)
so your saying that the ECU might read a different reading ???
Old Mar 3, 2007 | 04:29 PM
dartdc97's Avatar
Default Re: (rsdriver17)
have you started up the car yet?
Old Mar 3, 2007 | 11:56 PM
lsvtec664's Avatar
Default Re: (dartdc97)
whats up dudes wire tucks ar sick hope u get that **** done
Old Mar 5, 2007 | 01:38 PM
lsvtec664's Avatar
Default Re: (lsvtec664)
ttt
Old Mar 5, 2007 | 01:42 PM
rsdriver17's Avatar
no i am about to put it in, but someone said it might not work cause of the wires being to big. one of my friends burned up an ecu by using to big of wire to the injectors
Old Mar 5, 2007 | 07:53 PM
MotorMouth's Avatar
what year is the car... If it isn't an obd3 or up then you are fine. All those sensors are analog which means the voltage will be the same, the difference between the gauge of wire you used and the wire used by honda is negligable.
Only time you need to worry is if you have a mutiplex ECU that used digital pulses that are encoded or decoded by the ecu, in that case the larger gauge might cause some adverse readings.
You will be fine, I've done wire tucks with different gauge wire with no problem.
Old Mar 5, 2007 | 08:01 PM
dartdc97's Avatar
Default Re: (MotorMouth)
good info. didnt know that
Old Mar 6, 2007 | 02:20 PM
rsdriver17's Avatar
its a 93 teg obd1
Old Mar 6, 2007 | 07:26 PM
EKB18BPR3's Avatar
analog wires = youre ok
digital wires = not ok
correct me if im wrong
Old Mar 9, 2007 | 09:34 PM
MotorMouth's Avatar
Default Re: wire question reguarding wire tuck (98B00STED)
correct. or more tothe point analog ecu or digital ecu.
Old Mar 10, 2007 | 09:59 PM
rsdriver17's Avatar
Default Re: wire question reguarding wire tuck (MotorMouth)
alrighty ill go with that and see how it works out, thanks
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
freeplay
Audio / Security / Video
24
Mar 13, 2004 09:06 AM
5STAR3
Jan 22, 2004 03:47 PM
