d16z6 swap done and now some problems help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 1, 2007 | 06:05 PM
efking1985's Avatar
Default d16z6 swap done and now some problems help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok i just finished my d16z6 swap the car turns on fine here's the list the problems:
1.smokes comes out the raditor but the car is not over heating.
2.Dash lights dont come on checked all the fuses and none of them are blown.
3.white smoke comes out the tail pipe when i rev hi.
please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 1, 2007 | 06:09 PM
project midnight's Avatar
Default Re: d16z6 swap done and now some problems help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (efking1985)
how many miles does the motor have on it
Old Mar 1, 2007 | 06:34 PM
efking1985's Avatar
Default Re: d16z6 swap done and now some problems help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (project midnig
The motor has 124,000 and a new head gasket and a new water pump.
Old Mar 1, 2007 | 06:45 PM
well as far as the radiator smoke goes it could just be a bad thermostat but i'm not sure but the exhaust smoke is probably either fucked up cylinder walls, bad piston rings, bad valve stem seals, or just bad valves in general.
efking1985's Avatar
Old Mar 1, 2007 | 06:49 PM
efking1985's Avatar
bump anyone else?
dr_latino999's Avatar
White smoke is condensation, I.E. burning coolant.
Old Mar 1, 2007 | 07:25 PM
efking1985's Avatar
bump anyone else?
Old Mar 1, 2007 | 07:47 PM
efking1985's Avatar
what should i do?
Old Mar 1, 2007 | 07:50 PM
biggee's Avatar
find out how coolant is getting into your com,bustion chamber...the smoke is probably because exhaust is getting into your cooling system and coolant into your combustion chamber which is generally a headgasket or cracked head or cracked block or all of the above. pull your head off and check.
Old Mar 1, 2007 | 07:53 PM
ef_zcvtec's Avatar
Default Re: (biggee)
fix your head gasket leak....get a coolant combustion gas tester and find out if that is what it is..do a compression test, leak down test..
Old Mar 2, 2007 | 05:24 AM
efking1985's Avatar
Default Re: (ef_zcvtec)
it only smokes when im in vtec. and why doesn't the dash lighting come on?
Old Mar 2, 2007 | 08:33 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (efking1985)
maybe someone goofed torquing the head down eh ?
Old Mar 2, 2007 | 09:22 AM
danmdevries's Avatar
Dash lights = dimmer switch
xPRIMO
15
Jan 28, 2012 07:32 PM
ek9800
Sep 14, 2010 07:13 PM
Everyones Hero
Sep 6, 2006 07:31 AM
hollaback6
Jul 13, 2003 08:36 PM
